Thread: im lost here
Results 1 to 20 of 30
  1. #1 im lost here
    Saginaw mi
    i have a 97 gtp
    driving down the rd it just dies at a light oil light comes on
    stop and check oil it was full so i head home and it keeps dying and not making like a knocking sound is how id describe it the temp goes up not to the red but higher than normal get her home shut her off i have no idea what the problem could be i drove it alot yesterday with no problems whatso ever it just randomly started doing it out of the blue
  2. #2 Re: im lost here
    does the car actually die or is it the tach dropping to zero and the car still running?
  3. #3 Re: im lost here
    Saginaw mi
    ok car dies when a s/c starts to go bad or goes bad what noises does it make how does it effect the car?
  4. #4 Re: im lost here
    Saginaw mi
    it isnt so much of a knocking noise but more a bad screeching sound like metal rubbing together in a bad way its hard to say where the noise is comming from i cant seem to locate it i tried taking video but it wouldnt record sound
  5. #5 Re: im lost here
    Please..turn your phone sideways and type to us in some detail if you really want some help.
    You say you wouldn't describe a knocking noise in your first post, but temp is up.
    Second post is.. screeching noise.
    We are going to need a little history and background of what led up to this ...even that vid you mention would help.
  6. #6 Re: im lost here
    mine screeched pretty loud when i spun a bearing. then the car wouldnt run and it would just die randomly. then i couldnt start it at all.
  7. #7 Re: im lost here
    Saginaw mi
  8. #8 Re: im lost here
    i dont if it is just me but i cant hear the video, i can see it, but no sound
  9. #9 Re: im lost here
    Saginaw mi
    fixed added sound clip
  10. #10 Re: im lost here
    Saginaw mi
  11. #11 Re: im lost here
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    linky no worky
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  12. #12 Re: im lost here
    Saginaw mi
  13. #13 Re: im lost here
    Tyler, TX
    now it's an image
  14. #14 Re: im lost here
    Quote Originally Posted by 03GTPLE View Post
    now it's an image
    right click it and select OPEN LINK
  15. #15 Re: im lost here
    Tyler, TX
    thanks for the tip, that worked.
    ..but I have no idea what's going on with the car, I was just trying to help make sure we could see the video ...leave the diagnosing to the smarter ones...
  16. #16 Re: im lost here
    Saginaw mi
    does this sound like the s/c coupler? or maybe needs supercharger oil ? i am so lost this is my Dd and am having a hard time getting to and from work until i resolve and fix this plz help
  17. #17 Re: im lost here
    Donating Users kfish's Avatar
    Ohio
    sounds like a broken flexplate to me. as far as the car dying, does it die suddenly? or die slowly?
  18. #18 Re: im lost here
    Saginaw mi
    it dies pretty suddenly id say its not instant but it dies when i slow down if im driving it itll stay running but if i let off the gas then seh will die
    when its cool it will idle and run and not die but when she warms up is when it runs ****ty it also makes the noise regardless of the car temp
  19. #19 Re: im lost here
    check the easy, simple stuff to replace: the flexplate, all the idler and tensioner pulleys, the crank pulley, etc. if its an internal problem then its gonna start costing a lot more money.
  20. #20 Re: im lost here
    Saginaw mi
    went to see what the symptoms were today car would not start would not roll over would try to but then stop like it couldnt roll all the way over ... the battery was not dead so that was not the issue help
  1. car lost its up
    By sca555 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2010, 10:14 PM
  2. car lost 4th
    By Joe m in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2010, 10:08 PM
  3. I lost :(
    By nawarkk in forum Track Sessions and Kills
    Last Post: 11-06-2009, 04:00 PM
  4. lost
    By allenscott292002 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 07:09 AM
  5. I'm new! And lost!!
    By lindzabu in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2008, 07:32 PM
