Thread: Temp gauge not working
Results 1 to 3 of 3
  1. #1 Temp gauge not working
    Galien, Mi
    Just recently noticed that the temp gauge isn't working. The needle just stays at the bottom all the time. Coolant is okay, A/C working fine.
  2. #2 Re: Temp gauge not working
    Michigan
    I'd start by checking the wires going to the temp sensor. Its located just under the thermostat.
  3. #3 Re: Temp gauge not working
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    either that or your thermostat is stuck open.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  1. Temp Gauge stopped working???
    By GXP05er in forum 5.3L V8 (LS4)
    Last Post: 08-10-2010, 07:37 PM
  2. Temp gauge
    By SnowDrift in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2009, 01:39 AM
  3. 04 GTP Temp Guage Quit Working
    By trick94cobra in forum 04+ Specifics
    Last Post: 11-11-2009, 09:07 PM
  4. Temp control not working. Need help!
    By rangermike in forum Audio, Security & Visual Electronics
    Last Post: 05-02-2009, 03:43 PM
