Thread: cooling fans not running and overheating.
Results 1 to 5 of 5
  1. #1 cooling fans not running and overheating.
    if anyone can help me please. my car has a coolant leak from the lim gaskets. but am waiting to repair them. the car gets close to the 260 degree mark and i have to put the blower on to cycle air. i live in florida and its summer and already 100 plus out. i found the fans are not going on. i checked the fuse and its good. are there other fuses or relays i can check and or other things that would cause them to not work before i just replace the fan assembly. thanks in advance for your help.
  2. #2 Re: cooling fans not running and overheating.
    Charles City, IA
    There is a fan relay, buy a test light or multimeter and see if they have power.
    SMGPFC Two Nipple General
  3. #3 Re: cooling fans not running and overheating.
    you dont happen to know wich relay it is do you. not sure but im assuming that its one in the engine compartment and not in the passenger side cabin. thanks for your help.
  4. #4 Re: cooling fans not running and overheating.
    Topeka, KS
    Read the diagrams on the fuse box's. It will tell you which one the fans are. You can always pull and swap them too if they are the same.
  5. #5 Re: cooling fans not running and overheating.
    unfortunatly my vehicles box and cover does not designate a relay for the fans only a maxi fuse.
  1. Cooling Fans not kicking on.
    By kaylin4u in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2013, 12:07 PM
  2. Cooling Fans Not Working
    By 1FASTGTO in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-23-2011, 01:17 PM
  3. 1994 gtp cooling fans not working
    By almighty in forum 3.4L V6 (LQ1) DOHC
    Last Post: 04-01-2010, 09:39 AM
  4. Cooling fans only work with ac
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2009, 08:54 AM
  5. Cooling fans always on?
    By oldschoolpontiacs in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-14-2009, 01:29 AM
