I have the Napa solid lower mounts. My motor mount is appearantly shorter because the engine is a little crooked. I heard of guys spacing them out to fit right. Whats the best way to do this? I have a cherry picker, will I be able to lift the motor up enough to insert washers on top of the mount? Or will I have to screw with the subframe too? If thats the case, could I lift the motor up enough to insert fender shims to align the motor?
Thanks,
