Thread: 3800 supercharged.. grand prix
Results 1 to 7 of 7
  1. #1 3800 supercharged.. grand prix
    Jul 2010
    Usa
    I recently replaced my sons engine in his grand prix and all the connectors I have connected that I can see. but i have no temperature indication inside. can you help and maybe supply a connector diagram or where the sensor is located.
  2. #2 Re: 3800 supercharged.. grand prix
    the coolant temp sensor is underneath the thermostat housing on the lower intake manifold.
  3. #3 Re: 3800 supercharged.. grand prix
    Jul 2010
    Usa
    Thats what i thought but I do not have a conector for that sensor. as I stated before I am pretty sure that I have all the connectors plugged in. I do however have an extra connector on the wiring harness off the main trunk harness that has nothing connected. I don't believe i lost any cabling but not sure. it was a month of on going work before I replaced the motor..
  4. #4 Re: 3800 supercharged.. grand prix
    That particular sensor has a double element in it. One side feeds temperature to the PCM the other side to the gauge in the cabin. Likely the side for the cabin is bad.
  5. #5 Re: 3800 supercharged.. grand prix
    Jul 2010
    Usa
    I would agree except there is nothing plugged into the sensor on the block.
  6. #6 Re: 3800 supercharged.. grand prix
    Donating Users kfish's Avatar
    Ohio
    the wiring for that sensor can actually be disconnected from the harness, it plugs into the lim, and then into a bigger connector close to the front valve cover. maybe you left this connector on the other motor?
    The Boss Iceman6669's Avatar
    Jun 2011
    Back from the DEAD!!!
    2011 F-150 Yote powered
  1. 05 grand prix - not supercharged
    By cdutile in forum General Tech Discussion
    Last Post: 12-15-2009, 01:15 PM
  2. 1998 Pontiac Grand Prix GTP Supercharged
    By Spartan GL in forum Introductions/Noob Questions
    Last Post: 12-07-2009, 11:17 PM
  3. Okay can you drift a 98 grand prix supercharged?
    By thenervemann in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2008, 07:57 PM
