Thread: 3.8l supercharged engine
Results 1 to 11 of 11
  1. #1 3.8l supercharged engine
    Jul 2010
    Usa
    can anyone provide me with a copy of vaccum diagram for a 2001 grand prix gtp witha 3.8l supercharger. I had to replace the engine in my son's car and I need a diagram also a diagram of the electrical connections. please help
  2. #2 Re: 3.8l supercharged engine
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Here is the vacum diagram
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  3. #3 Re: 3.8l supercharged engine
    Jul 2010
    Usa
    Thanks
    I appreciate that
  4. #4 Re: 3.8l supercharged engine
    Jul 2010
    Usa
    Ok i have to ask also do you have a diagram for the electrical connections for the 3.8l. 2001 preferably. i labeled them but as you know when you change a motor all your labels are lost.
  5. #5 Re: 3.8l supercharged engine
    Bastard Reptile's Avatar
    Kansas City, MO
    Are you just needing to reconnect everything after a motor swap? The nice thing about how the plugs are arranged on the harness is that they will only go a certain direction, and they won't plug into anything else.
  6. #6 Re: 3.8l supercharged engine
    Jul 2010
    Usa
    yes thats what I am doing. i gues as long as the harness goes in the right place then it all should fit then.
  7. #7 Re: 3.8l supercharged engine
    Kansas City, MO
    It should, even the injector connectors are all in the right order. If you pay close attention, you should be good.
  8. #8 Re: 3.8l supercharged engine
    Oklahoma City
    and if you get stuck, just post up a picture and we can help you along...
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  9. #9 Re: 3.8l supercharged engine
    Apr 2009
    stockton ca
    On my install only one wire got me and it was the knock sensor on the back it really just isnt that bad of an engine to work on at all
  10. #10 Re: 3.8l supercharged engine
    GT Level Member hourang's Avatar
    commerce, mi
    Quote Originally Posted by Ibwrong View Post
    do you have one showing what that 3 prong thing is on top of the s/c near the tbody and what the other 2 lines coming from that 3 prong connector run to?
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  11. #11 Re: 3.8l supercharged engine
    Charles City, IA
    one goes to the hvac vacuum control, the other goes to the brake booster.
    SMGPFC Two Nipple General
  1. Engine issue 2006 gp supercharged
    By CoastGuard in forum General Tech Discussion
    Last Post: 11-07-2009, 11:46 AM
  2. LS9 Corevette Engine, Supercharged
    Last Post: 01-03-2008, 02:28 PM
