Thread: Cylinder 3 Misfire No Luck Please Help
Results 1 to 7 of 7
  1. #1 Cylinder 3 Misfire No Luck Please Help
    Jun 2010
    Nebraska
    I have cylinder 3 misfire but only under heavy load. I have brand new plugs (104's gapped to 55) and new Accel 8mm wires. I get the flashing light if I stay under throttle. If I am just driving around no problems or codes. Any ideas? An injector is $75 or new coils are about $45 a piece.
    98 GTP 3.4 Pulley, Bypass Mod, ZZP PCM, DP, FWAI
    07 ZX6 Kawi Cams, 40 Shot, -1+1, Bazzaz ZFi
  2. #2 Re: Cylinder 3 Misfire No Luck Please Help
    Free tests:
    Swap the plug wires at the coil for #3 and #6, does the misfire move to #6?
    Put one of your old wires back on #3. I haven't heard that Accell are either great or horrible wires, but a wire can break down or be bad. Need to rule it out.
    Pull the plug, any carbon traces or possibility that when you tightened it, it may have cracked? Sometimes working around the dogbones will put us at odd angles and that can crack plugs, might not be evident at first.
  3. #3 Re: Cylinder 3 Misfire No Luck Please Help
    Jun 2010
    Nebraska
    I'll try that tonight thanks! Is it possible one side of the coil is bad?
  4. #4 Re: Cylinder 3 Misfire No Luck Please Help
    Yes it is. Our coils fire both towers at once. Which is how you can swap the wires to see if the misfire changes cylinders. However I have found one tower to be broken, burned out etc in the past.
  5. #5 Re: Cylinder 3 Misfire No Luck Please Help
    SE Level Member Phyrstorm's Avatar
    Jun 2010
    Sioux Falls, sD
    I just had this problem and it was the coil. Coils for a 98 GTP at autozone were only like $26.
    Duralast/Coil - Ignition | Coil - Ignition | AutoZone.com
  6. #6 Re: Cylinder 3 Misfire No Luck Please Help
    Jun 2010
    Nebraska
    Quote Originally Posted by Phyrstorm View Post
    Thanks guys it was the coil
  7. #7 Re: Cylinder 3 Misfire No Luck Please Help
    gotta love the easy fix
  1. Possible cylinder misfire
    By TopGunSalo in forum 3.1L V6 (LHO/LG8)
    Last Post: 07-03-2010, 02:57 AM
  2. Cylinder Misfire!
    By AFBCamaro in forum Introductions/Noob Questions
    Last Post: 05-01-2010, 09:52 PM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  5. #4 cylinder misfire
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 06:16 PM
