Hey all, i need some advice, my car is a 2000 gtp and its been cutting out losing power & when i floor it the boost only goes ab halfway up. the check engine light is on the codes are p0135 & p0102 & p0443 . here is what i've already done 1.changed plugs 2.changed plug wires 3.clean maf sensor 4.replaced maf sensor 5. cleaned ics.6. replaced air filter 7. replaced idler pulley . 8'new sc belt n checked all the fuses. It seems to improve for a little while than gets worse again. i dont want to keep replacing parts if i dont need them. any suggestions or ideas would be greatly appreciated.
