Thread: oil: synthetic or regular??
Results 1 to 20 of 34
  1. #1 oil: synthetic or regular??
    SE Level Member WHITEGPGT06's Avatar
    Jun 2010
    DEARBORN, MI
    i have a 2006 pontiac grand prix gt supercharged 3.8 and i was wondering what kind of oil should i use ??
  2. #2 Re: WHAT KIND OF OIL SHOULD I USE WHEN GETTING MY NEXT OIL CHANGE, synthetic or regul
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    royal purple 5w30
  3. #3 Re: WHAT KIND OF OIL SHOULD I USE WHEN GETTING MY NEXT OIL CHANGE, synthetic or regul
    Portland Oregon
    I use Mobil 1 5w-30 every 3k with the bigger filter. Thinking about using castrol edge on the next change to see if it runs cleaner through the changes.
  4. #4 Re: oil: synthetic or regular??
    changed your title because i hated your caps and how long it was.
    also, did you search a little? there are at least 10 threads about this subject.
  5. #5 Re: oil: synthetic or regular??
    Donating Users Ibwrong's Avatar
    Oklahoma City
    Synthetic!
    2000 GTP - Project
    2000 Mustang GT
    2006 Charger
  6. #6 Re: oil: synthetic or regular??
    Donating Users Warbeaver's Avatar
    St. Louis
    synthetic
    always used valvoline but I have used Mobil 1 10w-30 every since getting into grand prixs. Many 3800 owners use it
  7. #7 Re: oil: synthetic or regular??
    Apr 2009
    stockton ca
    if you want to use synthetic use it if you wanna use conventional use it
    main thing is dont go over oil change intervals and use quality filters
    i personaly use synthetic what ever is in sale at the time i buy and its as cheap as conventional
  8. #8 Re: oil: synthetic or regular??
    Charles City, IA
    amsoil.
    SMGPFC Two Nipple General
  9. #9 Re: oil: synthetic or regular??
    Oct 2008
    mascoutah, Il
    2002 GTP
    custom HOK paint
  10. #10 Re: oil: synthetic or regular??
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    i use whatever synthetic is on sale too...just changed my oil with castrol syntec for $16 with a filter
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  11. #11 Re: oil: synthetic or regular??
    GT Level Member sportred04's Avatar
    Feb 2010
    indianapolis
    nice first post
    Quote Originally Posted by Warbeaver View Post
    I loved it when Bill Cosby said, " if you don't want white folks to look at you different, pull your damn pants up and learn to dress yourself"
  12. #12 Re: oil: synthetic or regular??
    GT Level Member GeosGP's Avatar
    Fenton, MI
    Gulf Of Mexico.
    2004 Grand Prix GTP Comp-G
    Stock, featuring more KR than you can shake a stick at
  13. #13 Re: oil: synthetic or regular??
    SE Level Member 00GTCoupe's Avatar
    Leeds, Maine
    I just got my GP and changed the oil to Mobil 1 5w/30 with an m1-101 filter and I can't believe how much easier it 'rolls' down the road. I would definitely run synthetics.
  14. #14 Re: oil: synthetic or regular??
    New Jersey
    "I just got my GP and changed the oil to Mobil 1 5w/30 with an m1-101 filter and I can't believe how much easier it 'rolls' down the road. I would definitely run synthetics."
    Am I the only one that has never noticed oil make a difference in performance whether it had synthetic or GoJo (with the grit) in it?
    I run Mobil 1 oil and Pureone or mobil 1 / K&N filters. I run synthetic because it doesn't darken near as fast from heat and holds up better overall. Not because i've ever felt an effect in performance. There are plenty of writeups on synthetic vs conventional oil on the net.
    However as Bio248 stated there are plenty of threads on this subject and these threads always start arguments.
  15. #15 Re: oil: synthetic or regular??
    Fenton, MI
  16. #16 Re: oil: synthetic or regular??
    put oil in your car. it will run.
    do not put oil in your car. it will not run.
  17. #17 Re: oil: synthetic or regular??
    HUDSON
    I use conventional oil, as the service records from the previous owner also indicate oil change intervals of 4-7k miles from day one with standard oil. It now has 150,000 and is very clean inside and runs perfect, only uses about 8oz ever 3000 miles.
    I change the oil around 3-4k miles, and use A/C or STP filter. (pf47)
    If it aint broke, I aint gunna fix it with synthetic.
  18. #18 Re: oil: synthetic or regular??
    Nov 2009
    Grand haven
    Quote Originally Posted by geosgp View Post
    gulf of mexico.
    this ^^^
  19. #19 Re: oil: synthetic or regular??
    Grocery Getter x2 goldgp's Avatar
    redneck tennessee
    My gp has 246,000 miles on the odo and 218k of it was with conventional oil.I think if u change it every 3k, thats all that matters.I just use pennzoil ultra and a k&n because i beat on it
  20. #20 Re: oil: synthetic or regular??
    Charles City, IA
    Quote Originally Posted by goldgp View Post
    pennzoil.....really?
  1. Switch to synthetic oil
    By c002529 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-01-2010, 11:24 AM
  2. Sythetic VS Regular 5W30
    By Fubisin in forum General Tech Discussion
    Last Post: 10-21-2009, 10:00 PM
  3. Replies: 3
    Last Post: 10-21-2009, 10:18 AM
  4. Synthetic Oil
    By Brammer in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-12-2009, 04:52 PM
