Okay, Stop right there. If you read the title and immediately though Diamond Forged, then please dont post. I am aware of the Diamond Forged pistons and am not crazy about forking out the money for them particularly when I can search and find other forged pistons that are considerably cheaper that are extremely close to what I need.
What I need right now is two things. First, complete specifications. I'll list what I already know below. Second, if you know of a forged piston that is a direct replacement for ours and is not a Diamond Forged piston, post that up.
Sock Piston, Connecting Rod and Engine info:
Compression Height: 1.205" (What happens when this number goes up or down?)
Wrist Pin Diameter: 0.905"
Ring Widths: 1.5mm, 1.5mm, 3.0mm
Bore Size: 3.800" or 96.5mm
Stroke: 3.400" or 86.5mm
Connecting Rod Length: ?, L32 Rods in particular
Block Height: ?
Deck Clearance: ?
Stock Head Gasket Thickness: ?
Im having a hard time coming to terms that a Diamond Forged piston is the only option out there for us. The 3800 has been around too long for that to be the case. And even if I have to customize a set I think I would still come out cheaper.
At any rate, I just wanted to see what options there were out there that maybe someone knew about and to get some of the information that I am missing.
I have found a couple pistons that match up nearly identically except the Wrist Pin Diameters. I dont think that would be a good place to use bushings so Id like to see if I can find the correct size.
Thanks in advance for your help.
