Thread: Bad Wheel Bearing/Hub.. does this effect MPG?
Results 1 to 7 of 7
  1. #1 Bad Wheel Bearing/Hub.. does this effect MPG?
    SE Level Member azmattaz06's Avatar
    Feb 2009
    Tucson
    My Grand prix is getting bad gas mileage and i badly need to replace the wheel bearing/hub.. Could this also cause bad MPG? my information center say's 19.8 mpg but there's no way it's getting even that.. if not the bug could it be the 02 sensor or something like that? plugs and wires are all new...
  2. #2 Re: Bad Wheel Bearing/Hub.. does this effect MPG?
    Donating Users
    South Deerfield, MA
    A wheel bearing that was worn out enough to cause a noticeable drop in MPG would be melting the hub from the amount of friction generated. You might need a new wheel bearing, but I would look elsewhere for the MPG drop.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  3. #3 Re: Bad Wheel Bearing/Hub.. does this effect MPG?
    Feb 2009
    Tucson
    I mean like could the bad electronic connection from the hub be causing some wrong readings or something like that? Just curious.. Also yea my gas mileage is pretty bad.. My dash will say like 120 miles then if I drive like 10 miles it'll be down to around 60.. It just drinks gas way to fast and I figured maybe the hub had something to do..
  4. #4 Re: Bad Wheel Bearing/Hub.. does this effect MPG?
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    no, your wheel bearing will have nothing to do with mpg...try fuel filter, plugs, wires...normal tune up crap
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  5. #5 Re: Bad Wheel Bearing/Hub.. does this effect MPG?
    SE Level Member e6600's Avatar
    Los Angeles
    Quote Originally Posted by azmattaz06 View Post
    youre not misfiring at all?
    98 grand prix gtp: stock until i fix problems
  6. #6 Re: Bad Wheel Bearing/Hub.. does this effect MPG?
    Donating Users kfish's Avatar
    Ohio
    you got a hole in the gas tank? lol
  7. #7 Re: Bad Wheel Bearing/Hub.. does this effect MPG?
    Feb 2009
    Tucson
    No misfire that i know of.. Tune wise it's pretty up to date.. other then Fuel filter and 02 sensor.. i've never changed those but i've only had the car for around 9 months..
  1. going on 4th Wheel Bearing
    By Toofastgs in forum Brakes/Suspension/Chassis
    Last Post: 05-16-2014, 04:24 PM
  2. Rear Wheel Bearing
    By codyc in forum Brakes/Suspension/Chassis
    Last Post: 05-04-2010, 01:25 PM
  3. 20 Mimute Wheel Bearing......HA!
    By Lvgrandprix2003 in forum General Tech Discussion
    Last Post: 04-14-2010, 07:24 PM
  4. Replacing wheel bearing
    By robahr24 in forum Brakes/Suspension/Chassis
    Last Post: 11-11-2008, 03:51 AM
  5. Wheel bearing questions...
    By Iron Indian in forum Brakes/Suspension/Chassis
    Last Post: 09-21-2008, 11:05 AM
