Thread: lost my oil pressure
Results 1 to 5 of 5
  1. #1 lost my oil pressure
    missouri
    I have a 2004 gtp with 140,000 miles. parked it on sunday, everything was fine. Started it on monday morning and the lifters were clattering. I checked the oil pressure with a mechanical guage to find I only had 4psi of oil pressure. I have changed the oil pump and inspected the pick up tube. I still have only 4-5psi of oil pressure(lifters still clattering from bleed down). What am I missing. To my knowledge the cam bearings and main bearings are not hurt. Car has not been driven. Any suggestions?
  2. #2 Re: lost my oil pressure
    Bastard Reptile's Avatar
    Kansas City, MO
    It could be anything really....oil pumps aren't well known for failling, but if you have one bearing that let go then you won't have oil pressure either.
  3. #3 Re: lost my oil pressure
    Banned - Busted For Scamming
    Feb 2009
    Check the bypass spring and piston in the oil filter housing, maybe the spring collapsed or broke?
  4. #4 Re: lost my oil pressure
    missouri
    I replaced the spring and cup when I did the oil pump.
  5. #5 Re: lost my oil pressure
    Portland Oregon
    You spun a bearing then. I know a guy that spun a cam bearing just driving down the road. Not common, but it has happened. Time to get an l26 short block and cam it
  1. car lost 4th
    By Joe m in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2010, 10:08 PM
  2. I lost :(
    By nawarkk in forum Track Sessions and Kills
    Last Post: 11-06-2009, 04:00 PM
  3. HELP lost 1st and 4th
    By davidl25 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-26-2009, 05:42 AM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  5. I'm new! And lost!!
    By lindzabu in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2008, 07:32 PM
