Thread: Pulled my spark plugs out today....have a look
Results 1 to 13 of 13
  1. #1 Pulled my spark plugs out today....have a look
    St. Louis Mo.
    These are/were Brisk LGS (Silver tipped) plugs I have had in my car for a little over 2 years now, they probably have about 50k miles on them. The tips were not bashed in or anything, but there is discoloration on them and a few have what appear oil marks on the threads, maybe you all can tell me?
    The top set of plugs sitting on the box are from the rear bank in order from left to right, and the bottom half are from the front.
    Any thoughts or input would be greatly appreciated.
    James Shafer
    St. Louis MO
  2. #2 Re: Pulled my spark plugs out today....have a look
    Nov 2009
    Grand haven
    I have never seen that style of plug.
  3. #3 Re: Pulled my spark plugs out today....have a look
    Quote Originally Posted by shawngtp View Post
    Same here.
    Normally all black deposits means you're running too rich or too cold.
    Slight browning with little to no deposits means just right.
  4. #4 Re: Pulled my spark plugs out today....have a look
    Charles City, IA
    They look ok, but I must say cheap plug FTW!
    SMGPFC Two Nipple General
  5. #5 Re: Pulled my spark plugs out today....have a look
    GTP Level Member
    Nov 2008
    MA
    Same here.
    exactly what i thought
    03 GTP - 13.8 @ 100 2.160ft
    99 GTP - DD
    *Operation Iraqi Freedom/Operation New Dawn Veteran*
  6. #6 Re: Pulled my spark plugs out today....have a look
    I say replace them with something better...like COPPER PLUGS
  7. #7 Re: Pulled my spark plugs out today....have a look
    Jan 2009
    Tallahassee, FL
    How the hell are you supposed to gap those?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  8. #8 Re: Pulled my spark plugs out today....have a look
    Apr 2009
    stockton ca
    you dont gap them
  9. #9 Re: Pulled my spark plugs out today....have a look
    St. Louis Mo.
    104s replaced them
    I got worried after I finished up putting in all the plugs, I started it and everything seemed to run fine, then I saw some smoke come from the rear manifolds. I was like ! I thought maybe one of the plug wires was resting on one of the header tubes or something else. I started looking around and couldnt find anything.
    Then I remember when we first installed the headers over a year ago, they smoked cause of the oil on our hands when we were positioning the headers. The heat from the mani's through the header tubes heated up the oils that were on the tubes from me touching them.
    At least that is what I hope it was I checked all the wiring and the upper manifold O2 sensor cable to make sure everything was not touching the manifolds, same goes for the plug wires and the rubber boots.
    I hope that was it
    James Shafer
    St. Louis MO
  10. #10 Re: Pulled my spark plugs out today....have a look
    Largo, Florida, United States
    what kinda plugs are those?
    they are ****ing HUGE
  11. #11 Re: Pulled my spark plugs out today....have a look
    What? They are no bigger than any other plug...they are just 4 prongs at the tip vs. 1.
  12. #12 Re: Pulled my spark plugs out today....have a look
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    Weird looking plugs
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  13. #13 Re: Pulled my spark plugs out today....have a look
    SE Level Member GTPcoupe's Avatar
    Feb 2010
    Canada
    I have Brisk plugs in my coupe. Those are awesome.
    '99 GTP coupe - Growing mod list/summer car
    '98 GTP Sedan - Winter ride, 315,000+kms and going strong!
  1. Spark Plugs?
    By gahris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2010, 03:13 PM
  2. What Spark Plugs do you run?
    By RiceBurnt6 in forum Off Topic Discussion
    Last Post: 02-05-2010, 04:47 PM
  3. 5.3L V8 Spark Plugs
    By 06usafgxp in forum General Tech Discussion
    Last Post: 01-29-2010, 09:23 PM
  4. Spark plugs
    By Chleby in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-16-2009, 10:43 PM
  5. What spark plugs?
    By Dwhip in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-25-2009, 08:21 PM
