Thread: 42.5# injectors?
Results 1 to 20 of 33
  1. #1 42.5# injectors?
    any cons on the lucas 42.5# injectors? i tried a search on the other forum but even on a T1 line the search sucks. any help is appreciated
    Bastard Reptile's Avatar
    Kansas City, MO
    I'm not sure about the lucas ones, but I've got the Bosch green top (lightning) injectors. Don't have a problem with them at all.
    yea i also heard the green-tops are fine, but theres a deal for the lucas' and just need to know if there are any issues with them or not
    Topeka, KS
    Doesn't Curtis use the Lucus' ones?
    Kansas City, MO
    if they plug and play, I'd run them. if you don't like them you can always sell them.
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    Quote Originally Posted by fst View Post
    A lot of people run the Lucas w/o any problems. You should be fine. I was going to go with those, but got a deal on the Lightning injectors.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
    SE Level Member JASON 77's Avatar
    IL
    ran them for awhile, never had any issues. would run them again.
    SE Level Member beast3300's Avatar
    aren't the lucas ones affliated with GM in some way? I thought I read that somewhere.
    Black 98 Regal GS: best run 13.95@99.75
    99 Red GP L36: 15.5 in 1/4
    I remember someone saying one of them had a better spray pattern for the 3800 and i think it was the lucas. I know they have both been run with sucess. And i would go with whichever you can find cheaper. Over on lightning board you can get them for pretty cheap with lower miles.
    SE Level Member TooMch's Avatar
    St. Louis, MO
    Quote Originally Posted by my97gtp View Post
    I heard the same thing about the Lucas. I am currently running 39# Cobra injectors which are made similar to the lightning 42.5s. They have been fine. I've heard our cars prefer a pencil pattern spray because it has further to travel than in Fords. Both the 39# and 42.5# are cone patterns. This is good for dispersal if your injector is further down the runner.
    All that being said, I've never found anyone who had any hard data to support that one runs better in our cars than the other. The other thing I've heard is that the Lucas 42.5s are easier to tune at lower rpms than the motron 60s but I know that's not what you asked.
    I think the best advice has been given. Go with which ever one you can get the best deal on. You'll be OK.
    2004 GTP CompG
    wizair| LQ4| S2IC| 3.0| 1.9RR| RS12YC| 160°| 39#|TOGX|3" Hogan DP| Corsa| tune
    2007 = 13.034 @ 103.68 (TOGX, AL103, ZZP DP)
    2004 = 14.576 @ 94.34 || 2005 = 13.822 @ 97.57 || 2006 = 13.224 @ 99.98 (PEMs,TR6IX, RT DP)
    SE Level Member chrisgtp's Avatar
    st.louis
    lucas are running strong in ** car
    1.9, 4"custom fwi, 3.0/2.9 zzp dub pulleys, AFC 2.2/powrtuner 180 t-stat drilled, rat heat sheild, slp headers 3"cat back flow 40's ported blower/n* tb custom intercooler 2.041 60' 8.644 1/8 mile 1000 12.85@107.5
    well i went ahead and bought the lucas' stupid me, its listed under zzp's site as what they sell but i wanted some real feedback on them which are good thanks to you guys. :-)
    SE Level Member Gandalf's Avatar
    North Florida
    42.5's are great but you gotta have a way to tune the PCM for them, Powertuner, HPT or at least an AFC.
    Without a way to compensate for the extra fuel your car will run like crap.
    2K3 GTP Redfire Mettalic,1.95 RR's,90#Springs, Tog's, RAT TB,JMB FWI,PRJ Wires,MSD Coils, AGX Struts & Vogtland Springs, Next Level Front+Rear Swaybars & STB's,MOOG Endlinks,17" SLP Rims, F-Body Brakes, Ractive Oval Tips,Perf Shift Added, Powertuner,WB O2,Lucas Flowmatched 42.5 injectors, Mag Snout w\3.4
    I live here. UR LOSN's Avatar
    Rockford, IL
    Lucas 42.5's, I have not heard anything wrong with them. most of everyone I know over here have them, and like them.
    good luck!!
    Oklahoma City
    please don't forget to have the IFR table tuned in your PCM, your car will run RICH without that done. I have had them for about 3 years and they are running great....about to have them cleaned and flow tested. Hopefully they can spray enough fuel for me to run 11's.
    Donating Users suprchrgd's Avatar
    Noblesville, In
    42.5's here for about a year. no issues as of yet.
    i didn't think the 42.5's were good much past 12's?
    Oklahoma City
    Quote Originally Posted by suprchrgd View Post
    well they are good into the low 12's. my ipw's are around 18 ms at 6300rpm. They are close to being done. Hopefully they can be good for 11s we'll see though.
    ZZP S2IC-XP-CC105/ls1 retainers-PPSC-N*-85MM MAFF-HAI K&N-180Therm-AL103-8RIB PULLEYS-SFI 5%OD BALLANCER-DOUBEL ROLLER-CCPUSH RODS-ZZP 3KSTALL-15/16 3:29-ZZP IS- TOGS-3"BORLA EXHAUST-ELIMASLIP-42.5 LUCAS-ZZP LOGS
    Kansas City, MO
    FWIW, The Cobras can run deep in 11's on their stock 42.5 injectors. Might not have much value here, but I just thought I'd put that in.
    SE Level Member Coogles's Avatar
    Quote Originally Posted by Reptile View Post
    That's because they have 8 cylinders. They need to make less power per cylinder to get the same performance.
    That's why the 4cyl turbo guys need HUGE injectors to make good power.
    Forest Green 1998 GTP Sedan - SOLD
    VS, 3.2, TOG, GMPP Suspension, 3EP Tune
    13.179 @ 106.57 w/2.005 60'
    Kansas City, MO
    Even still....it takes X amount of gasoline to make Y amount of horsepower.
