Thread: Coding cylinder 3 missfire and cylinder 3 injector port open
Results 1 to 3 of 3
  1. #1 Coding cylinder 3 missfire and cylinder 3 injector port open
    SE Level Member MATHEWSMAN1969's Avatar
    MARTINSBURG,OHIO
    Car has started running lousy and i changed the basics after the scan like plugs wires coil pack finally checked injector #3 and found it had no negative injector pulse checked the wire all the way to the ecm and it lit up the whole way is this telling me i need a new ecm or has anyone experienced this it shuts down the cruise control and my gas mileage has fell to 15 from 28 ive ordered a new ecm hoping that will be the fix
    EXCEED THE LIMITS !!
  2. #2 Re: Coding cylinder 3 missfire and cylinder 3 injector port open
    MARTINSBURG,OHIO
    New ecm fixed it right up
  3. #3 Re: Coding cylinder 3 missfire and cylinder 3 injector port open
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    perfect..glad you figured it out
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  1. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
  2. Cylinder 3 misfire...please help!!!
    By swifty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2010, 07:21 PM
  3. 5 Cylinder GTP
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-11-2009, 10:42 AM
  4. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
  5. How to fill cylinder with air?
    By TheOtherNick in forum General Tech Discussion
    Last Post: 01-15-2009, 11:55 AM
