Thread: Need Help Car issue
Results 1 to 6 of 6
  1. #1 Need Help Car issue
    Nov 2008
    wichita
    I have a 98 GTP, I replaced the fuel pump about 6 months ago. And every since we installed the new one, It has been running VERY loud, you can hear it outside the car. A few weeks ago the noise stopped and then after about 1 hour of driving the car will just stop and go dead, or will die and start back up while driving. Tensioner (sp) broke on the serpentine belt. I had to use the one off the supercharge to get it home and still have not hooked the supercharge back up. The Fuel pump is running louder then ever now, own the way home the car would not go faster then 45 and feels like its going to die. Any ideas
    MOD:AL104s,CAI,DHP TUNED PCM MOD I have not installed:180 Thermostat,3.4 pulley, boost gauge, A/F Ratio Gauge MOD I HAVE NOT ORDERED YET: DP,
  2. #2 Re: Need Help Car issue
    Nov 2008
    wichita
    No check engine light also
  3. #3 Re: Need Help Car issue
    Nov 2008
    wichita
    Just went outside and pulled fuel pump, and did fuel pump speed control thing. Fuel pump still screaming at me. Call is running ok, But it always does after I let it sit for a while then it gets worse then It will do same as before
  4. #4 Re: Need Help Car issue
    Topeka, KS
    Since you're for Wichita get on www.kcpmc.net and join. There's several people on there from Wichita that would probably be more than willing to help you out. I used to live down there. Also we try to help each other out on that site \ car club too.
  5. #5 Re: Need Help Car issue
    Nov 2008
    wichita
    No longer in Wichita, Im in Arkansas now
  6. #6 Re: Need Help Car issue
    Nov 2008
    wichita
    Will this work W Body Store and Do I put together myself using canister
  1. MAF Issue
    By prostallion347 in forum General Tech Discussion
    Last Post: 03-30-2010, 11:36 AM
  2. Please Help!!! AC Issue
    By sb76 in forum General Tech Discussion
    Last Post: 07-22-2009, 03:03 PM
  3. GTP pcm issue with ZZP
    By Regalgs98 in forum PCM Tuning
    Last Post: 02-18-2009, 02:16 AM
  4. I have a big issue please help me
    By Goany in forum General Tech Discussion
    Last Post: 12-02-2008, 02:51 PM
  5. Help with this issue please
    By TDCRacing in forum General Tech Discussion
    Last Post: 07-05-2008, 05:00 PM
