Thread: slight misfire cylinder 3 only
Results 1 to 11 of 11
  1. #1 slight misfire cylinder 3 only
    May 2008
    McHenry IL
    any ideas ??? i was told my ignition coils suck but that would also effect whatever other number is paired with the coil correct? its not throwing a misfire code but i was scanning my car with the GM TECH II at school a few days ago for ****z n giggles
  2. #2 Re: slight misfire cylinder 3 only
    Wichita
    Slight missfires are normal arent they? If not, check your spark plugs.
  3. #3 Re: slight misfire cylinder 3 only
    Charles City, IA
    Hook a scope up to it.
    SMGPFC Two Nipple General
  4. #4 Re: slight misfire cylinder 3 only
    Banned - Busted For Scamming
    Feb 2009
    Whats a scope? Lol
  5. #5 Re: slight misfire cylinder 3 only
    Charles City, IA
    Whats a scope? Lol
    telescope duh!!
  6. #6 Re: slight misfire cylinder 3 only
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    if u had a bad coil both cylinders would more then likely be dead or misin, check plug,wire,injector,or you chipped a piston pretty much the only thing it could be
  7. #7 Re: slight misfire cylinder 3 only
    Pull the plug Joe.
    Told you guys it wouldn't last on a 3.4" and manifolds.
  8. #8 Re: slight misfire cylinder 3 only
    Feb 2009
    Yea it is the front bank!! Damn cast manifold.
  9. #9 Re: slight misfire cylinder 3 only
    May 2008
    McHenry IL
    lol nah guys my ignition wire was chopped..... lol slighty chopped but its all ok i got MSDS on the way :P
  10. #10 Re: slight misfire cylinder 3 only
    May 2008
    McHenry IL
    and by the way i did have a fluke scope hooked up lol
  11. #11 Re: slight misfire cylinder 3 only
    Jan 1970
    Maquoketa, Iowa
    Check the rest of your wires while your at it. I'm talking the car and yourself
  1. Cylinder 3 Misfire
    By Spartan GL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-27-2010, 11:24 PM
  2. Cylinder 3 misfire...please help!!!
    By swifty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2010, 07:21 PM
  3. Cylinder 6 misfire with a p0102
    By icolex1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-29-2009, 05:16 PM
  4. Cylinder #4 misfire
    By Kompton in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-28-2009, 08:41 AM
  5. #4 cylinder misfire
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 06:16 PM
