Thread: installing welded pasecrusters
Results 1 to 7 of 7
  1. #1 installing welded pasecrusters
    Serena, IL
    how bad is it to install welded pasecrusters?
  2. #2 Re: installing welded pasecrusters
  3. #3 Re: installing welded pasecrusters
    Serena, IL
    10-4. i figured that was he norm for all installs
  4. #4 Re: installing welded pasecrusters
    either way youre gonna have to pull the motor pretty far forward with the front of the motor clear for more room to pull. rear header first, then the front, then the crossover, then tighten everything up all at once.
  5. #5 Re: installing welded pasecrusters
    if they're welded, then they're basically a two piece.
    This means, rear assy then front header.
  6. #6 Re: installing welded pasecrusters
    Outer Space
    02 GTP 13.6 @ 100mph - SOLD
  7. #7 Re: installing welded pasecrusters
    ^^Good call chief
    You don't even have to remove the Rear VC...just install the front header last and ratchet strap everything forward.
  1. Installing new HU
    By CMURDAx in forum Audio, Security & Visual Electronics
    Last Post: 06-13-2010, 12:00 AM
  2. installing HUD
    By joshsGT in forum Audio, Security & Visual Electronics
    Last Post: 03-16-2010, 10:47 PM
  3. installing LOC
    By Preston in forum Audio, Security & Visual Electronics
    Last Post: 09-12-2008, 12:08 PM
  4. Installing HUD?
    By retski420 in forum General Tech Discussion
    Last Post: 03-17-2008, 02:29 PM
