Thread: Code: theft deterrent fuel enable
Results 1 to 16 of 16
  1. #1 Code: theft deterrent fuel enable
    Jul 2008
    sumter,south carolina
    on the way home today car ran fine... as soon as i pull in my driveway car starts buckin, smokin and stalled... scanner said MAF code at first... clean MAF, start car up and it shuts off within a few seconds... now im getting theft deterrent fuel enable... i forget code number..... is this ****? what do i need to fix it?
    02 GTP with mods 05 GP for DD
  2. #2 Re: Code: theft deterrent fuel enable
    Apr 2009
    Maine
    Maybe this will help.
    http://www.grandprixforums.net/f18/p...help-1338.html
    Looks like it could be as simple as trying a spare key.
  3. #3 Re: Code: theft deterrent fuel enable
    Jul 2008
    i forget about the search button when im freakin out lol.... i dont have a chip in my key... so im still lost... ty though.
  4. #4 Re: Code: theft deterrent fuel enable
    Apr 2009
    Maine
    Actually there is a chip in your key, you just can't see it like with the Buicks.
    It's less likely that that's the issue but it's still worth a try.
  5. #5 Re: Code: theft deterrent fuel enable
    Jul 2008
    So my friend... ASE certified thinks one of the wires in ignition switch broke. this sucks ass i got **** to do tonight.... any way to bypass security system?
  6. #6 Re: Code: theft deterrent fuel enable
    Jul 2008
    JGTP we posted at same time... i didnt know that. i guess ill try and get a new key tomorrow from dealer. if anyone has any other ideas as to bypassing this **** let me know.
  7. #7 Re: Code: theft deterrent fuel enable
    Apr 2009
    Maine
    Apparently you can buy a PK3 key on ebay for like 10 bucks, have any place cut it and program it yourself.
    Someone posted about it not-so-long ago. I'll see if I can find the thread.
    Beats paying $70 for a new key. And on top of that, a lot of the time you have to pay them to program it too.
    EDIT: I was just reading this thread
    http://www.grandprixforums.net/f81/e...ing-28294.html
    Could be the fuel pump resistor or fuse. Check the fuse first. Mine blew right after I got my car. I didn't make the connection though, because my car wouldnt start at all after it blew.
    But this actually makes more sense because it happened while you were driving the car. My fuse blew like 500 feet out of my driveway. Of course I didn't know that was the problem at the time, so I had it towed to the shop where I bought it. 50 cent fix... DOH!
  8. #8 Re: Code: theft deterrent fuel enable
    Jul 2008
    FWIW i re scanned and its p 1629c
  9. #9 Re: Code: theft deterrent fuel enable
    Jul 2008
    ok disconnected battery for 30 mins... cranked car and it runs... but security light is flashing, i drove around yard and it seemed to run fine at low speeds... but when i put in park rpm's drop a good bit then idles up to 1500 rpm's and evens out. stays running.
  10. #10 Re: Code: theft deterrent fuel enable
    Jul 2008
    Quote Originally Posted by J GTP View Post
    just seen where you edited.... where is the fuel pump resistor? or is fuse the resisitor? lol i know where the fuel pump fuse is.... its good.
  11. #11 Re: Code: theft deterrent fuel enable
    Jul 2008
    nobody else has had this happen before?
  12. #12 Re: Code: theft deterrent fuel enable
    Jul 2008
    well, i started messin with car this mornin. p1629 is gone and replaced with p101 (MAF) which is what it started out as yesterday... security light still flashing but no security code... is goin on.
  13. #13 Re: Code: theft deterrent fuel enable
    Jul 2008
    after spending most of morning ****in with it... it is now back to normal running condition... doing a security relearn as we speak for PK3 to get the light to go off.... exception of blinking security light it cranks right up and runs good. from what i have read on other forums... changing the gauge cluster can cause this... and i swapped out limited edition cluster awhile back... im hoping this was the culprit.
  14. #14 Re: Code: theft deterrent fuel enable
    Jul 2008
    well security relearn doesnt seem to be working... car still runs fine, took it out for a long spiried drive and no problems... security light still flashing after car is cranked and lasts for about 10 minutes and shuts off.
  15. #15 Re: Code: theft deterrent fuel enable
    Apr 2009
    Maine
    Have you tried unplugging the MAF sensor? The car may die once or twice with it unplugged, but the PCM should learn to run without it by the second or third try. If it doesn't stay running, at least you'll know that the MAF is (probably) ok, or at least not the only problem.
  16. #16 Re: Code: theft deterrent fuel enable
    Jul 2008
    got everything resolved except blinking security light
  1. Theft System Not Programmed............????
    By joshuayobal in forum General Tech Discussion
    Last Post: 09-20-2010, 11:30 AM
  2. Fuel line to fuel filter cracked need help asap
    By Jays98GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2010, 04:20 PM
  3. Car disabled due to theft system AFTER ZZ PCM installed
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2008, 09:38 PM
  4. Catalytic Converter Theft
    Last Post: 02-24-2008, 09:49 PM
