Thread: door panel
Results 1 to 5 of 5
  1. #1 door panel
    OHIO
    I have a 2000 GTP, having trouble removing the passenger read door panel. Is there a special tool need to remove screws behind the door handle?
  2. #2 Re: door panel
    SE Level Member Feather Head's Avatar
    Wausau
    They are torx bits, as for size that I dont remember
    99 GT - SD Headders, EGR delete, Custom Tune, HV3
    70's Sears-Fully built OHV Briggs Single
  3. #3 Re: door panel
    OHIO
    Thanks FH
  4. #4 Re: door panel
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    be careful and try not to break the plastic clips that hold it in, try and pry straight out and from close to where each clip is located.
    98' GTP, 18's, BMR Adjustable Forward & Rear Lateral Arms, BMR Tubular Trailing Arms, Intense PCM, CAI, drilled rotors, 5% Tint all around
  5. #5 Re: door panel
    GTP Level Member Bedwards's Avatar
    Calgary, Alberta, Canada
    Quote Originally Posted by 98GTPCALGARY View Post
    This. They break so easy.
  1. Question to those who have or will have their front int. door panel off
    By mntnbiker in forum Audio, Security & Visual Electronics
    Last Post: 06-30-2009, 09:13 AM
  2. "Chirping" in door panel (squeaks)
    By harrydunn in forum General Tech Discussion
    Last Post: 06-06-2009, 01:03 PM
  3. door panel
    By kittie1342 in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-26-2009, 07:54 PM
  4. Door panel
    By chrisp847 in forum Audio, Security & Visual Electronics
    Last Post: 02-18-2009, 02:26 PM
