Thread: new pistons: going down the checklist
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 65
  1. #1 new pistons: going down the checklist
    Jan 2009
    Tallahassee, FL
    Well since I probably have a chipped piston I'm going to replace all of them. Being as I can't afford a whole motor from Morad I'm going to go the route of new pistons/rods. Would ot be worth it if I ncan get ahold of L32 pistons/rods? Also my idea is not pulling the crank, just the pistons, or should I go ahead and replace the main bearings to?
    Right now my list of parts is pistons/rods, rod bearings, timing chain/dampner, coupler, oil pump?, and gasket set. Anything I should replace while I'm in there that will be worth it? I don't have a lot of money so I'm trying to make this rebuild as cheap as possible but don't want to cheap out to much. I have a friend who has a shop and experience rebuilding motors who will be helping me.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  2. #2 Re: new pistons: going down the checklist
    Charles City, IA
    There is a short block on here for $300, you will be over that in parts.
    SMGPFC Two Nipple General
  3. #3 Re: new pistons: going down the checklist
    Banned - Busted For Scamming
    Feb 2009
    The rods maybe. Pistons are the same AFAIK.
  4. #4 Re: new pistons: going down the checklist
    Fort Atkinson
    Get the short block in the classifieds. Otherwise if you can't find L32 pistons/rods L67's will work. I'm currently rebuilding a 04 GTP motor and had to settle on used L67 Pistons/rods from Morad. You'll need a complete gasket kit for the motor,rod bolts,rod and main bearings at a bare minimum. If you have the bottom end apart it would be foolish to not do all the bearings.
  5. #5 Re: new pistons: going down the checklist
    May 2008
    staten island,NY
    you are aware that you need to bring this to the machine shop right?
  6. #6 Re: new pistons: going down the checklist
    yeah if you're not replacing the short block with another stock one... might as well do a build from the ground up.
  7. #7 Re: new pistons: going down the checklist
    Apr 2009
    stockton ca
    get a short block You will need to have the block machined and all the other parts you will be over 600 easy my block new pistons and all that cost me 1200
  8. #8 Re: new pistons: going down the checklist
    Quote Originally Posted by TorqueAutoMotiv View Post
    8.5 or 9.4?
  9. #9 Re: new pistons: going down the checklist
    Jan 2009
    Tallahassee, FL
    Well damn, I was hoping to avoid a shop cause I never have that money, it'll take me a while to get the money just to do my original plan. The yards around here almost never have L67's, kinda wish I could go with an L26 with a stock tune and a bigger pulley but I know that's not a bad idea.
    Right now I'm just trying to figure out the best way for me to go with this situation. I want to do it right with what I can afford. I have heard of guys just dropping the pistons and rods but leaving the crank in the motor.
    77 Morris Garage B
  10. #10 Re: new pistons: going down the checklist
    Apr 2009
    stockton ca
    Get a na block you dont need a l67 block
  11. #11 Re: new pistons: going down the checklist
    Apr 2009
    stockton ca
    i went 8.5
    didnt know if it would effect the ca smog bs
  12. #12 Re: new pistons: going down the checklist
    true. CA smog is quite crazy...
  13. #13 Re: new pistons: going down the checklist
    If it makes you feel any better I have an entire set of pistons/rods from a L67 out of a babied '02 GTP. They look basically brand new and have NO carbon at all on them. IIRC, all you would need then is a crank and bearings to technically rebuild it. PM me if your interested.
  14. #14 Re: new pistons: going down the checklist
    Jan 2009
    Tallahassee, FL
    I would if I had a tuner
    77 Morris Garage B
  15. #15 Re: new pistons: going down the checklist
    Jan 2009
    Tallahassee, FL
    Looks like I might be lucky, the local junkyard has a L67 in a 97 Park Ave. I'll grab the short block and throw new gaskets, chain, oil/water pump on it, with new springs for my heads. Throw my top end and accessories on it since this thing looks a little rough. All the aluminum is pretty corroded on the top end.
    77 Morris Garage B
  16. #16 Re: new pistons: going down the checklist
    Jan 2009
    Tallahassee, FL
    Would this be advisable for a setup?:
    L26 top swap
    ported blower, 3" DP, plog, K&N cone, 180 thermo, get a DHP PCM, run like a 4" pulley
    Was thinking about gasket matching the heads and intake while I have it all apart to.
    Really the only way to know is to scan but locally there are more L32s in good shape than the one L67 I found.
    77 Morris Garage B
  17. #17 Re: new pistons: going down the checklist
    Fort Atkinson
    Email Morad,I got a set of used L67 pistons and rods for $100. The pistons where coated on the tops and skirts so I don't know if they sent me L32 pistons/rods or not...but anyways then you could just rebuild the bottom end. or go the short block route if you find a good one.
  18. #18 Re: new pistons: going down the checklist
    in 2003-2005 there were a lot of hybrids
  19. #19 Re: new pistons: going down the checklist
    Feb 2009
    Quote Originally Posted by Sandman View Post
    L26 top swap
    You are being paranoid. I have an l36 with with mods in my sig, run a 3.4 no knock on stock tune. You will be fine. Especially if you port the heads. I would not advise a used l67 if you are not getting new pistons and such. They all are toast, people abuse them. Grab a good looking 100k l36 and put new seals and bearings in and be good to go. All 2 blocks ive gotten for l36's were in PERFECT shape with perfect specs. Just around 100k is when its a good idea to replace the bearings for long life.
    I dont run water meth need to take that out of my sig lol
  20. #20 Re: new pistons: going down the checklist
    Jan 2009
    Tallahassee, FL
    I'd rather get it right the first time ya know. It won't be a full port job, just to smooth thing out a little maybe.
    77 Morris Garage B
  1. Are my pistons screwed?
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 01-14-2010, 04:41 PM
  2. installing pistons in the l67
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2009, 04:45 PM
