Thread: oil pressure issues?common or not?
Results 1 to 20 of 20
  1. #1 oil pressure issues?common or not?
    henderson co
    I have a 02 40th gtp low oil pressure light comming on,oil is full, starting to get eng noise once it warms up. is there a know problem in the oil pumps with pressure relief valve?
  2. #2 Re: oil pressure issues?common or not?
    the oil pumps are pretty beefy and usually dont go bad. if your oil pressure light is on that means there is less than 5 psi, which is already very, very bad. that noise is probably the bottom end saying "AAAHHHHHH!!", but only you can figure that out.
  3. #3 Re: oil pressure issues?common or not?
    Ohio
    exactly what bio said! i had a similar prob this past summer. my relief valve was stuck though. the result, bottom end took a ****
    00 GTP demodded and forsale
  4. #4 Re: oil pressure issues?common or not?
    Wichita, KS
    I would strongly suggest to quit driving it, and drain your oil and make sure your not panning for gold. (bearing material shavings)
    Oil is the life line/blood of any engine, EVERYONE should have a oil pressure gauge installed regardless. That's just my opinion though.
    ~F~
  5. #5 Re: oil pressure issues?common or not?
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    these may be dumb questions but..
    1. what should oil pressure normally be at? 50?
    2. wheres the relief valve? its the spring with cap over it isnt it?
    cause im kinda havin a prob with oil pressure too. Not jackin your thread gxp.
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  6. #6 Re: oil pressure issues?common or not?
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    I have a gt (l36) and is normally between 30-40 at idle and 70-80 at wot
  7. #7 Re: oil pressure issues?common or not?
    Quote Originally Posted by bbptech View Post
    oil pressure should be around 40+ psi around idle and 60+ at WOT.
  8. #8 Re: oil pressure issues?common or not?
    i go from 50 to 25 at idle. somethings gota be wrong any suggestions? and oil is brand new and full same with oil filter
  9. #9 Re: oil pressure issues?common or not?
    Ohio
    what bio said for oil press. and the relief valve is located in the side of the front cover. it is held in by the oil filter adapter. when you remove the adapter the valve will slide out. yes it is the spring with the cap over it.
  10. #10 Re: oil pressure issues?common or not?
    Jul 2008
    Livonia MI.
    Id say theres something wrong with the press. valve, has it ben changed or is it stock?
  11. #11 Re: oil pressure issues?common or not?
    my car only idled at 15-20 psi when it was hot, if that makes a difference to you.
  12. #12 Re: oil pressure issues?common or not?
    if your talking about the spring and cap 97gtsc, then it has be replaced.
    Bio - mine will start at 50 when i first start it then drops to 25 when it warms up. so not necessarily an abnormal thing maybe?
  13. #13 Re: oil pressure issues?common or not?
    no, its probably fine. all the excessive oil pressure people try and run (50+ at idle) is basically useless to have. you just need the oil pressure in the upper RPMs to keep the motor lubed.
  14. #14 Re: oil pressure issues?common or not?
    Jul 2008
    Livonia MI.
    X2^^^
  15. #15 Re: oil pressure issues?common or not?
    henderson co
    Can you just replace the spring and cap? There is light metalic when you pull the stick.sounds like time to pull it apart. I just bought the car from the orig owner, figuring it needed a eng.
  16. #16 Re: oil pressure issues?common or not?
    yes the spring and cap can be replaced.
  17. #17 Re: oil pressure issues?common or not?
    Jul 2008
    Livonia MI.
    ^^^^If u can see shiny metal flakes then your motor is on its way out!
  18. #18 Re: oil pressure issues?common or not?
    Wichita, KS
    Having a oil pressure gauge is nice, and what your gauges reads maybe different from another's from what I have seen first hand and learned.
    The pressure sending unit may not be bad, just "different" with different gauge kits. Your not getting a 100% accurate reading because its usually not a very nice quality sending unit. It gives you an eye ball window look at what it is, not spot on.
    So with that, any kit you buy and install is fine, and what it reads is fine, just remember what it says cold, and warm, and if that changes, such as goes lower than normal, then thats your heads up you have a problem before you trash your engine.
    I have a carbon fiber Auto Meter oil pressure set, and on the stock engine it was installed on it always read 60 PSI regardless of cold or warm, it never dropped. When I built my current engine from the block up, I reused the sending unit, and now it changes from cold to warm like some others on there report. Maybe I jarred something loose with the R&R of the sender to where it reads different, dont know. It was odd in deed.
    ~F~
  19. #19 Re: oil pressure issues?common or not?
    so long as you have about 15 psi or so at idle youre cool. at WOT its good to have at least 50 psi, but youre supposed to have 10 psi for every 1k rpm.
  20. #20 Re: oil pressure issues?common or not?
    Charles City, IA
    Quote Originally Posted by GR8racingfool View Post
    ~F~
    My autometer carbon fiber oil pressure gauge always moved. I had about 50 psi at idle and 60-70 driving and wot.
    SMGPFC Two Nipple General
  1. Common Acronyms
    By TyroElite in forum General Tech Discussion
    Last Post: 11-07-2019, 07:51 PM
  2. Common Problems?
    By deadmittens in forum General Tech Discussion
    Last Post: 09-28-2009, 12:31 PM
  3. Is this common?
    By boomboom in forum Brakes/Suspension/Chassis
    Last Post: 07-24-2009, 02:05 PM
  4. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
  5. Common Accronyms
    By TyroElite in forum Forum Bugs/Suggestions
    Last Post: 01-03-2008, 11:31 PM
