Thread: When i put my car in reverse it vibrates bad and makes a noise. Whats causing this?
Results 1 to 9 of 9
  1. #1 When i put my car in reverse it vibrates bad and makes a noise. Whats causing this?
    Indiana
    i have ssac headers and when i put my car in reverse it sounds like something is rubbing it vibrates my car and makes a loud noise. is this my downpipe hitting the sway bar? if so how do i fix it? Its soo annoying also my car vibrates a lot when in drive and idling when stopped. is this being caused by the downpipe too? if i raise my rpms to just under 1000 it goes away. (i know its not sc coupler too.) how can i fix this
  2. #2 Re: When i put my car in reverse it vibrates bad and makes a noise. Whats causing thi
    Indiana
    Is it the downpipe hitting the Sway bar? anybody know?
  3. #3 Re: When i put my car in reverse it vibrates bad and makes a noise. Whats causing thi
    downpipe hitting the sway bar or the cat pipe hitting the underside of the car.
  4. #4 Re: When i put my car in reverse it vibrates bad and makes a noise. Whats causing thi
    Your O2 sensor is making love to your underbody.
    Take a mallet to it to make some clearance.
  5. #5 Re: When i put my car in reverse it vibrates bad and makes a noise. Whats causing thi
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    I have the same problem with the same headers. THanks for this I will try it to
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  6. #6 Re: When i put my car in reverse it vibrates bad and makes a noise. Whats causing thi
    GT Level Member EmEaston24's Avatar
    Pittsburgh
    My cat hits the underside of the car and does the same thing...and for some reason it seems like my exhaust is way far to the right. Just get under the car and have a look see.
  7. #7 Re: When i put my car in reverse it vibrates bad and makes a noise. Whats causing thi
    Indiana
    thanks for all replies
  8. #8 Re: When i put my car in reverse it vibrates bad and makes a noise. Whats causing thi
    Charles City, IA
    Quote Originally Posted by jacobmh27 View Post
    I told you this months ago. Take a hammer and make some room around the 02 sensor.
    SMGPFC Two Nipple General
  9. #9 Re: When i put my car in reverse it vibrates bad and makes a noise. Whats causing thi
    Naugatuck CT
    I know I been out of the country and forgot I still have to get home
  1. Car makes odd howling noise
    By SDGTP99 in forum General Tech Discussion
    Last Post: 07-20-2011, 01:50 PM
  2. grinding noise in reverse
    By wrathofthunder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 08:24 PM
  3. gtp shakes/ vibrates
    By backinblackgtp in forum General Tech Discussion
    Last Post: 12-13-2009, 01:42 AM
  4. Car still vibrates....please help
    By bcrosby51 in forum General Tech Discussion
    Last Post: 03-30-2009, 04:40 PM
  5. Whats this noise? (Video)
    Last Post: 02-27-2008, 02:05 AM
