Thread: Noise at bout 2000-2500 RPM
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21 Re: Noise at bout 2000-2500 RPM
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Get a stethoscope and poke around and listen.
    ive done this already. many times actually. Cant pinpoint it out. Very loud from exhaust
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #22 Re: Noise at bout 2000-2500 RPM
    as im typing all this im in the garage so when i figure something out i walk right over to the computer. the rear head, i can push the pushrods down and there are still spongy like they havent even seen oil yet. maybe that explains why i had 25 psi of oil pressure when i heard the noise in town. But the weird thing is i had full oil in there. When i left the house i was reading 50 psi. Gonna check the oil pump right now and will fill u all back in.
  3. #23 Re: Noise at bout 2000-2500 RPM
    in a house
    Man, that does not sound good at all. So basically it was fine at first start up and after driving it you lost oil pressure causing the lifters to collaspe and this was the noise you heard? I hope that new motor isn't toast
  4. #24 Re: Noise at bout 2000-2500 RPM
    the motor is fine. i caught it pretty early. gonna prime the system then take the vc's off to see if they pumped up this time.
  5. #25 Re: Noise at bout 2000-2500 RPM
    Charles City, IA
    Junk oil pump?
    SMGPFC Two Nipple General
  6. #26 Re: Noise at bout 2000-2500 RPM
    new as well. we checked that last night to make sure.
  7. #27 Re: Noise at bout 2000-2500 RPM
    Charles City, IA
    You plastigauged everything right?
  8. #28 Re: Noise at bout 2000-2500 RPM
    nope. didnt even know what that was until after i had the block together.
  9. #29 Re: Noise at bout 2000-2500 RPM
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    is plastic guageing were you put the lil peace of plastic on the rod bearings and tighten um down then take the bearing cap of to check the back lash???
  10. #30 Re: Noise at bout 2000-2500 RPM
    Charles City, IA
    no it checks bearing clearances.
  11. #31 Re: Noise at bout 2000-2500 RPM
    Feb 2010
    ohio
    thats what i ment my bad
  12. #32 Re: Noise at bout 2000-2500 RPM
    think the problem might be figured out. took the front cover off again, and the bolts to my machined pump cover show wear marks on them from the chain. obviously because i put 1 metal timing cover gasket on it. picked up 2 paper gaskets today to space it out somemore. We will see what happens tomorrow when the motor goes back in and gets started. on the rear header, cylinder 6 showed a slight exhaust leak.
  1. Distributor O-Ring leak. $2500!?
    By rw53104 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 08-20-2011, 06:52 AM
  2. We have passed 2500 Members
    Last Post: 11-26-2008, 08:31 AM
  3. 2500 Bucks
    By jacobmh27 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-12-2008, 12:48 PM
