Thread: Best Valve Springs for 1.9 Ratio Modified Rockers
Results 1 to 11 of 11
  1. #1 Best Valve Springs for 1.9 Ratio Modified Rockers
    Indiana
    What is the best valve spring that would go with 1.9 modified ratio rockers? would the 90# springs be fine or do i need the 105# springs. do i need modded retainers for both? thanks
  2. #2 Re: Best Valve Springs for 1.9 Ratio Modified Rockers
    105# seem to wear the valvetrain less. do not get comp springs. yes you need modded retainers.
  3. #3 Re: Best Valve Springs for 1.9 Ratio Modified Rockers
    Jan 1970
    Maquoketa, Iowa
    L76 springs from the g8's, order from the dealer, its like $26 for 5 of them so you would have to get 3 sets.
  4. #4 Re: Best Valve Springs for 1.9 Ratio Modified Rockers
    Indiana
    Quote Originally Posted by FoSHO99 View Post
    Do you need modded rockers for the L76 springs?
  5. #5 Re: Best Valve Springs for 1.9 Ratio Modified Rockers
    Portland Oregon
    Quote Originally Posted by gtp02 View Post
    I think you mean retainers. And yes you will.
  6. #6 Re: Best Valve Springs for 1.9 Ratio Modified Rockers
    ^^You mean modded "retainers" right? No...just the L76 ones IIRC. I used #90 LS6 springs/retainers when I did my XP setup...or more commonly known as yellow 90's.
    Or...get Crow 105's
  7. #7 Re: Best Valve Springs for 1.9 Ratio Modified Rockers
    Jan 1970
    Maquoketa, Iowa
    different retainers, but order the springs from gmpartsdirect, not the dealer like i said above.
    The L76 springs are supposed to be a little better than the LS6's but either would do just fine.
  8. #8 Re: Best Valve Springs for 1.9 Ratio Modified Rockers
    GTP Level Member Scimmia's Avatar
    QCA, IA
    You need LSx retainers whenever you use LSx style springs, which includes the L76 springs. You do NOT need the modded retainers, those are just modded for clearance.
    2001 Buick Regal LS - Almost Stock
  9. #9 Re: Best Valve Springs for 1.9 Ratio Modified Rockers
    Indiana
    lol i ment modded retainers. my bad
  10. #10 Re: Best Valve Springs for 1.9 Ratio Modified Rockers
    Indiana
    would the L76 retainers work?
  11. #11 Re: Best Valve Springs for 1.9 Ratio Modified Rockers
    GT Level Member rolyat's Avatar
    OKC
    For the L76 springs, yes. I just got done installing some 1.9 rockers with L76 springs and retainers. I got 16 springs and retainers on ebay for $60.
  1. Installing 1.9 Ratio Modified Rockers
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2010, 10:50 PM
  2. ZZP Modified rockers
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-02-2009, 09:22 PM
  3. modified pedistels for rockers???
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 02-06-2009, 05:26 PM
