It seems like that after my custom tune by PRJ that I'm getting into boost a lot earlier than I used to. Is this even possible by changing the tune?
Your probably just noticing more timing and torque management being removed, as well as a better fueling curve to get your fuel trims locked in. Also probably lowered the PE enabled throttle position so your going into PE earlier... etc.
