Replaced the Fuse for the Reader
got a Cylinder 3 Misfire
Its ether my spark plugs or fuel injectors
gah ='[ Tax return get here soon!
Is it running rough? I always get nervous when I hear cyl 3 misfire. That plug is easy to get to, pull it and make sure it's not smashed.
I had a cylinder 3 misfire yesterday. The damn plug wire fell on my header lol
just a side note zef...all the times I've seen your signature...did you know you spelled MORAD wrong? LOL
higher gas consumption is a sign of chipped piston isn't it?
Since a cylinder is starving...or there is nothing there...perhaps LOL
How about pull the damned plug out and look at it?
pull the plug on cylinder three and see if its bent.
front middle?
Do you know what a spark plug is?
If so, look at your coil packs and find the number three. Then look to the wire directly to the right of it. (granted you're facing the engine from the front of the car) follow that wire and it will go to the spark plug on the front side of the engine in the middle.
Find a socket for spark plugs (has a rubber grommet inside so you don't **** up the insulator) and take it off.
Then stop being a tool.
