Stock pulley, Downpipe and Intake. A few times over the past month it has gotten bad enough to hear in midrange rpm through first and second gear. i always use 93.
Sure it isn't burst knock due to a bad plug/coil/wire?
Could also be the downpipe hitting the sway bar...since you have the downpipe.
i just did the plugs and wires about 2k miles ago... parts store didnt have autolites, so i got ac delco 606's i believe and stock wires. may be a dumb question but how do i go about checking the coil? i dont really think its the DP, this sounds more like internal engine noise.
video man...video...cant really diagnose an engine noise over a keyboard if your smellin' what I'm steppin' in
seafoam the top end. a haynes or chilton will tell u how to check the resistance in your coils. remember to check the primary and secondary side of the coils.
I'm wondering if I got the wrong plugs! I went Advanced and I told the guy I was on a budget. Now I'm no ASE mechanic (but not affraid to get dirty), and I do ask a sh*t load of questions before I do any work on my 2003 GT. So when I went to Advanced they gave me Champion copper plugs....I just replaced my Cat, plugs and wires. I got Autolite "professional" wires, and those champion plugs. When I accelerate I can hear a faint knocking and I'm not sure If I should replace my plugs AGAIN!!!!! I only hear it when I hit the gas. Also does anyone know if using a magnaflow cat (direct fit) is louder at the top! Or am I just an idiot and screwed something up! It's much louder than it used to be. There is something at the top of the down pipe (which wasn't on my stock cat. Just wondering!!!!
I didn't know you asking me a question since my first post on this topic was after you. Anyway ...no bigs! I just opened the box and put them in my car! The counter person at Advanced said they were pre-gapped!
What should they be gapped at?
