Thread: Chipped pistons options
Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 153
  1. #61 Re: Chipped pistons options
    Fort Atkinson
    thats crazy that this happened stock in such an extreme way.
    That is why I'm so pissed/confused and utterly dissapointed about the whole ordeal.
    Quote Originally Posted by blowfishRus6 View Post
    hone it, put some new pistons in it, gap the rings bigger. should run for a long time then.
    Cylinder walls have ZERO ridge and look good,gotta find pistons,then proper ring gap and maybe headers to help with the heat issues. If this car had a 5spd I'd buy it back from her and build it.
  2. #62 Re: Chipped pistons options
    Donating Users blowfishRus6's Avatar
    g.a.
    after doing all that work i would want to keep it.
    ive been looking around for the stock ring gap then what others have made it bigger too but not much luck yet.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  3. #63 Re: Chipped pistons options
    Fort Atkinson
    I might just go to the local dealer and ask them. They have a good service department so I figured I'd pick there brains. Wish I could find out if L67 pistons will work in this thing. I can't find L32's anywhere and all the motors I find are either super high mileage or they want $1500+ for one with lower mileage. Morad has nothing also.
  4. #64 Re: Chipped pistons options
    Fort Atkinson
    When I trashed my stock pistons, I looked for the cause. Turned out the stock ring "end gap" was too tight even as checked on used stock rings. When the rings get hot under heavy use, they expand. In my case to the point of closing the gap from expansion. When this happens a lot of drag occurs against the cylinder wall. This drag then is also pressure in the ring grove of the piston. Stock pistons are short on the deminsion from top ring grove to the top of piston. This is the part that most frequently breaks/chips as the rings drag on them. You would have to install new rings and gap them at .020 to .023" to stop this end gap lock up.
    I got this from another forum,so I'm still gonna find out what stock Gm recommendation is from the dealer and see what the difference is. Now to find out about L67 pistons.
  5. #65 Re: Chipped pistons options
    Sorry about the coating answer...you said what was the difference and that really is it...the coating. AFAIK everything is the same...I think even the pins are identical too. IMO, only thing I would put any money into is the rod bearings and the rods themselves. That is just me though...I'd get some powdered rods and Clevite Bearings...that way when you rebuild it...it'll be stronger...you'll have less a chance of this happening IMO. Also, I'd get a 3" Downpipe for it...you can get them catted too...but after seeing this...I'd want the thing to breathe...and since you have the engine out...it'll be easy as hell to do. Plus, better performance when you need it and better MPG's to boot.
  6. #66 Re: Chipped pistons options
    g.a.
    yea man find out what gm says. if its .15 or so i would deff run it at .20
    i was talking to a guy that runs spray with his set up and they say you need to gap the rings even bigger with spray also. he said the only draw back was oil blow by past the rings and you might burn some oil. he said with his large ring gap he has not burned any oil that he can notice. so i would not be afraid to go a little big.
    its slow.
  7. #67 Re: Chipped pistons options
    Fort Atkinson
    I'm thinking about just getting some L67 pistons,reusing the rods,new rod/main bearings,maybe some gasket matching...maybe,ebay headers and re-ring/hone. I think then It would be much better then factory and have some safety factor too. Thanks for the replies everything is coming together in my head now
  8. #68 Re: Chipped pistons options
    Nov 2009
    Grand haven
    Let us know what happens!!
  9. #69 Re: Chipped pistons options
    PA
    Quote Originally Posted by Thinkmoto View Post
    L67 pistons work fine in an L32. New bearings and you should be good to go.
    2001 GSE
  10. #70 Re: Chipped pistons options
    Fort Atkinson
    Quote Originally Posted by Zef_66 View Post
    Ok Thanks for the reassurance. Now to weasel the money out of my ex to fix her car So whats a good excuse for headers
  11. #71 Re: Chipped pistons options
    Gas mileage and not having to spend money on another rebuild sound like good excuses to me...just tell her the exhaust is broken and that is how much the new stuff costs.
  12. #72 Re: Chipped pistons options
    Fort Atkinson
    True true, wish I could just get the car back for myself. It would be nice to recoup something from the divorce
  13. #73 Re: Chipped pistons options
    PA
    Why do you want to build up the car for an ex anyway? Just fix it back to running condition. If it happens again, let her on her own.
    2001 GSE
  14. #74 Re: Chipped pistons options
    Fort Atkinson
    It sounds F'd up but i told her I'd fix it for her if she paid for parts. When we going through everything I bought her a car so she had something. The car didn't even make it til the final divorce date. I'm not building it in my eyes,just making it reliable again.
    Anyone got some L67 pistons they'd part with? Please
  15. #75 Re: Chipped pistons options
    I got some L36's w/ rods...but then you would for SURE need headers because of the higher compression.
  16. #76 Re: Chipped pistons options
    Fort Atkinson
    I'll keep it in mind.
  17. #77 Re: Chipped pistons options
    PA
    I have two, if that helps.
    Does Ed Morad have any pistons?
    Well, I do have a set of 6 TRW pistons that you can put on your old rods in my FS thread.
    2001 GSE
  18. #78 Re: Chipped pistons options
    Fort Atkinson
    I'm waiting on a response from Morad,last time I checked they had a 150kmile block but no pistons/rods. Are those TRW's a direct fit? You said they are for a GN?
    I have my ex convinced I can make the car reliable,so she'll keep it now. So, I'm seriously looking guys.
  19. #79 Re: Chipped pistons options
    USED to...pretty sure he stopped yanking sh!t apart and just selling stuff as a whole now that he really has moved on to bigger and better things.
  20. #80 Re: Chipped pistons options
    i pay to play badbrad's Avatar
    Dec 2008
    hueytown, alabama
    rob, pm me when ya can about the top ring gap
  1. Are my pistons screwed?
    By 04BlackComp_G in forum General Tech Discussion
    Last Post: 01-14-2010, 04:41 PM
  2. installing pistons in the l67
    By GTPJOE90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2009, 04:45 PM
