i have been tossing around the idea of grabbing a block & just wanted to know if i should go with a L32, L26, L67, L36? i am going to be sticking with an m90 build.
L26...L36's are cheaper as I have a FULL bottom end sitting here taking up space with 80-ish K on it from a H-Body. Again...with the Higher comp you don't need as much boost to make it fast but you DO need more cooling mods are they are more/easier prone to knocking.
so does the L26 i think
