Thread: E-Test Fail - Next Steps
Results 1 to 7 of 7
  1. #1 E-Test Fail - Next Steps
    SE Level Member toolmanz's Avatar
    Ontario, Canada
    I just failed, for the first time, an E-Test on my 98 GTP. It passed 2 years ago with the same mods. I did a search on this in the forums. Here are the results for 1649 RPM
    Limit/Result
    58/20 HC
    0.32/0.25 CO
    435/864 NO
    14.8 dilution
    Curb idle was passed for HC and CO with a better margin between limit and result and NO was shown as NA.
    These are the things I will do:
    1) Clean and check the EGR Valve
    2) Check plugs wires etc.
    3) cat replace?
    My mods are in my sig. I have a level 1 DHP PCM but haven't done a tune yet with Will. The car passed 2 years ago. Also, I have one of those digital boxes where you can increase fuel/air mix for particular RPM ranges in order to reduce knock. If that is set up too rich or not rich enough can that be causing the problem?
    Any help would be appreciated. I do have a car scanner and ill be doing a baseline and then after looking at #1 and 2 above, I will re-run.
    TIA
  2. #2 Re: E-Test Fail - Next Steps
    EGR working?
    Adding a sig might help.
    What region are you from?
  3. #3 Re: E-Test Fail - Next Steps
    Ontario, Canada
    Oops ... I guess I forgot. I will do that now.
    I am in Canada - Ontario.
    Here are the mods on:
    1998 Arctic White GTP
    1.9 rockers;Custom Ram Air+FWI;LS1 MAF;73mm TB;18" Hankook+AE077's;3.25 pulley;Shimmy (ported stock)header;3" DP high flow cat+3"SS to Magnaflows;DHP PCM - Stage 1;
  4. #4 Re: E-Test Fail - Next Steps
    I'm inclined to vote its knocking as well which means you have no timing. Not sure if that'd effect NOx levels.
    Most find they can only run a 3.4 with that level of mods. Typically takes a cam or an intercooler to break 3.4 safely.
    I meant what region of ontario lol
  5. #5 Re: E-Test Fail - Next Steps
    Ontario, Canada
    Just east of Oshawa ....
  6. #6 Re: E-Test Fail - Next Steps
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    yes 3.25 way 2 small, needs alot more.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  7. #7 Re: E-Test Fail - Next Steps
    Just west lol, but the EGR can be malfunctioning because when you get a tune thats one of the codes they pull. If you have the stock PCM, throw that in and see if if pops a code, also I wouldn't suggest running the blower belt with that small pulley, you could blow the front bank.
  1. Fail
    By Will5600 in forum General Tech Discussion
    Last Post: 11-08-2009, 06:46 PM
  2. Fail FTW
    By mpiacent in forum Track Sessions and Kills
    Last Post: 08-25-2009, 01:04 PM
  3. FAIL!
    By SlowM90 in forum Off Topic Discussion
    Last Post: 02-26-2009, 02:14 AM
  4. FAIL
    Last Post: 11-01-2008, 03:45 PM
  5. quick steps to check how bad the chain snapped?
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-22-2008, 12:07 PM
