Thread: Spark Plugs and Wires
Results 1 to 10 of 10
  1. #1 Spark Plugs and Wires
    Daytona Beach FL
    Im changing out the spark plugs and wires on my 2001 GTP. The only mod is a K&N cold air intake. been trying to search for the best plugs on the forums but the lyngo you guys are useing is confusing me.
    What are the stock plugs?
    I understand that supercharged engine needs copper core spark plugs. Im gonna pick them up from autozone. Is this what i need in the link below?
    AutoZone.com | | Spark Plug | AUTOLITE SPARK PLUG
    And for the Wires should i upgrade to 8mm or just go with stock 7mm. I use the 8mm in my formula firebird v8, i figured they would be good in the GTP as well.
    2001 Grand Prix GTP - K&N CAI, Everything else stock
    1995 Formula Firebird - Too Many Mods to list
    www.formulaw66.cz28.com
  2. #2 Re: Spark Plugs and Wires
    Outer Space
    Stock plugs are AL606. Those are correct. .60 gap IIRC
    02 GTP 13.6 @ 100mph - SOLD
  3. #3 Re: Spark Plugs and Wires
    Daytona Beach FL
    Quote Originally Posted by Lawngoose View Post
    thanks what about the wires for my set up (stock with CAI) 7 or 8mm
  4. #4 Re: Spark Plugs and Wires
    it wont matter. the only reason to buy nice plug wires is if you plan on taking them on and off a lot so they wont get all torn up. i ran stock plug wires on my car even when i was heavily modded.
  5. #5 Re: Spark Plugs and Wires
    Daytona Beach FL
    cool makes me feel better. the 7mm are cheap enough to change once a year with plugs anyways.
  6. #6 Re: Spark Plugs and Wires
    SE Level Member Royalblue's Avatar
    Waldorf, MD
    what is the correct heat range sparkplugs for a 2001 Gtp with 3.4 pully & cold air intake
  7. #7 Re: Spark Plugs and Wires
    Apr 2009
    stockton ca
    al104's
  8. #8 Re: Spark Plugs and Wires
    Quote Originally Posted by Royalblue View Post
    Heat Range: The hottest plug you can get away with...without knocking.
    Correct Route to go with 3.4" Pulley and a Cold Air Intake: A new short block.
    Have fun chipping pistons
  9. #9 Re: Spark Plugs and Wires
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    Are the 104's good for headers, FWI, Overkill PCM, and 3.4 pully???
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  10. #10 Re: Spark Plugs and Wires
    Apr 2009
    stockton ca
    yes
  1. Plugs and Wires
    By Squishy in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-09-2009, 09:51 PM
  2. New Spark Plugs and Wires
    By rileystanek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 02:31 AM
  3. CAN IT run without spark wires???
    By TMOTA503 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-13-2008, 08:34 PM
  4. Specific Plugs/Wires
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-26-2008, 06:48 PM
