So I'm about to pick up some mildly ported heads for cheap and was wondering if it would even be worth it if I got a 3 angle valve job done on them. The heads are basically just port matched on the intake and the exhaust right now, but I was planning on at least getting them milled down a bit for higher compression. I plan on staying stock cam for now and I have a GenV/IC/1.9 rocker setup (and possibly some spray ) in the works. So would a 3 angle valve job be worth it for that setup or do you guys think just the port matching and milling will be fine?
