Thread: 3 angle valve job worth it?
Results 1 to 15 of 15
  1. #1 3 angle valve job worth it?
    GTP Level Member Smokin2000gtp's Avatar
    Jul 2008
    Dekalb, IL
    So I'm about to pick up some mildly ported heads for cheap and was wondering if it would even be worth it if I got a 3 angle valve job done on them. The heads are basically just port matched on the intake and the exhaust right now, but I was planning on at least getting them milled down a bit for higher compression. I plan on staying stock cam for now and I have a GenV/IC/1.9 rocker setup (and possibly some spray ) in the works. So would a 3 angle valve job be worth it for that setup or do you guys think just the port matching and milling will be fine?
    2000 Silvermist Grand Prix GTP Coupe
    Mods-Custom Thrasher CAI|Ceramic Coated S&S Headers|3.4" pulley|ZZP S4 Blower|Powrtuner|PRJ 10.4mm wires|HIDs|F-Body brakes|Koni's and Voglant's|
  2. #2 Re: 3 angle valve job worth it?
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    I dont c y not, how much more will it be than a reg. valve job?
  3. #3 Re: 3 angle valve job worth it?
    Three angle is what I have had done on three sets of heads. It's what my local shop considers "standard". Five angle is supposed to be the best of the best for valve jobs.
  4. #4 Re: 3 angle valve job worth it?
    Apr 2009
    stockton ca
    The heads i was doing for my build we did a 3 angle valve job on them its just a 45* for seat a 30* to narrow seat areaand a 60* to widen throat honestly Im not sure how a 5 angle would work on our heads theres just not that much seat material
    But yea most machines shops 3 angle is standard
  5. #5 Re: 3 angle valve job worth it?
    Donating Users blowfishRus6's Avatar
    g.a.
    if anything i think the throat needs to be widend a bit and smoothed out the most.
    looking at a set of stock heads, it looks like the throats could use some massaging.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  6. #6 Re: 3 angle valve job worth it?
    Apr 2009
    stockton ca
    Yea i had my heads looking good but forgot to magnaflux n found out they were junk i was pissed
    It also cost me my togs
  7. #7 Re: 3 angle valve job worth it?
  8. #8 Re: 3 angle valve job worth it?
    Jul 2008
    Dekalb, IL
    Ok ya after looking at some pics of our heads they do come with a 3 angle valve job stock. Whoops I didn't know it was standard. Well I guess if the stock valve job isn't in too great of shape I'll just get it redone with a standard valve job instead of a 5 angle. Anyone know the going price of a standard valve job?
  9. #9 Re: 3 angle valve job worth it?
    it really depends upon where you take it, but id recommend an engine builder.
  10. #10 Re: 3 angle valve job worth it?
    Apr 2009
    stockton ca
    dont the heads come stock with a 3 angle valve job?
    My heads only had the 45* visable i think they only get the 30 and 45 not the 60
  11. #11 Re: 3 angle valve job worth it?
    Apr 2009
    stockton ca
    Quote Originally Posted by Smokin2000gtp View Post
    200 bucks or so
  12. #12 Re: 3 angle valve job worth it?
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    honestly this may sound stupid but whats magnafluxed?
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  13. #13 Re: 3 angle valve job worth it?
    May 2008
    McHenry IL
    i dont no how to explain it but its a intense process and it checks for cracks and imperfections in the heads. who exactly they do it.... not sure lol
  14. #14 Re: 3 angle valve job worth it?
  15. #15 Re: 3 angle valve job worth it?
    Apr 2009
    stockton ca
    its just powder that you spray on the head or block where you are testing you magnatize the area and the powder wil collect and stick in the crack its a really simple check
    When i did my heads i was to umped up and moving to fast and forgot
    the powder is a bit pricey
  1. What are they worth?
    By NEILZVETTE in forum Tires & Wheels
    Last Post: 07-07-2009, 02:48 PM
  2. JET MAF worth it????
    By jimgimli in forum 5.3L V8 (LS4)
    Last Post: 06-13-2009, 07:43 PM
  3. Worth it or not
    By robahr24 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-27-2008, 01:45 PM
  4. is it really worth it?
    By 99prixgt in forum PCM Tuning
    Last Post: 08-09-2008, 12:38 PM
  5. What do you think it's worth?
    Last Post: 03-22-2008, 05:23 PM
