i am thinking about getting the 1.9 rockers from zzp. i was wondering if i need to get new pushrods or springs also. and will i notice a different when i get them on?
thanks!
thanks!
From ZZP's website: ZZ Performance
They will work fine with stock springs and pushrods. The only thing I would worry about is if you are running stock springs, and they are high mileage, you might want to replace them so you don't break one.These work with all stock or aftermarket pushrods, lifters, springs, retainers.
As for noticing a difference, yes, you will.
Higher Ratio Rocker Arms
get the yella terra rollers. They come with everything you need. You might want to get a set of springs, I use L76 springs, $80, they work well.
fwiw you only notice the gains in the upper rpm range
alright. is there anyway to change out springs with out taking the head off?
alright thanks. and i saw that there is 1.9 and 1.95 should i just stay with 1.9 also will have to get a tune?
yes you should get a tune, especially because you already have a zzp tune for the gtp. Do you have a way to scan your KR and A/F ratio?
You will want some springs better than stock to prevent valve float on 1.9's or 1.95's. Also make sure to get a new set of valve seals when replacing springs.
your going to need lsx style retainers as well.
CAAaaaaaaaMMMMMMM
Or go home
The rope trick is an old trick that instead of pressurizing the cylinder via the spark plug hole, you basically bring the cylinder to TDC and push a bunch of rope in the spark plug hole. Then when you take off the retainers, the spring doesn't fall all the way down in.
On some vehicles, it can fall enough to not be able to pull it back up. Just a good rule of thumb if you are not sure to stuff some rope in. And if you have the plugs out to change the valves, turning most engine over isn't hard. In fact, if you are going to use the air compressor method, you have to find the point where both valves are closed, so you still have to turn the engine over at some point.
But I was just giving an alternative that I have heard. I never used it. Actually, I never changed valves on a head with them still on the engine. But for someone that doesn't want to make a tool to pressurize the cylinder or doesn't have the means to do so, this is a good second choice.
