Thread: KR/scan tool
Results 1 to 4 of 4
  1. #1 KR/scan tool
    SE Level Member ldyzluvdis06's Avatar
    Springfield, IL
    I have been running with my current set up for a few few months now.....
    ZZP S3 IC|ZZP pcm|HAI|Autolite 104's|Plog|ZZP 3" cat-less DP|SLP catback|180* t.stat|3.1|ZZP ported blower|Ported LIM|AFC||Aeroforce scan gauge|LC-1
    and i have never seen ANY KR...well today i was making a couple WOT runs and was seeing anywhere from 1-5* of KR
    the only thing that has changed was the other day the top came off of my breather...so i fixed (temp. duct tape fix) that because i thought that it may be causing a vac leak then made another few runs and was seeing the same thing.
    wideband was reading about 11.3's, LTs locked at 0!
    i know it is hard to tell w/o a scan posted but i have no way nor know how! any ideas?
    also what is the best way to log a scan and post it online so you guys can help me out?
    Thanks in advance!
    DL
    A.K.A.... "Danny Lahr" on CLUBGP
  2. #2 Re: KR/scan tool
    Oklahoma
    You can go here:
    Scan Depot dot net
    And you can upload your scans there directly from the .csv file or spreadsheet file.
  3. #3 Re: KR/scan tool
    Springfield, IL
    what is a cheap scan tool to use though?
  4. #4 Re: KR/scan tool
    Oklahoma
    Well there are several out there on the market. But to scan for KR you need one that supports GM enhanced parameters. I dont know if HP Tuners has a built in scan tool or not, but if you went that route, for a little more you would have the tuner as well.
    But for strictly scan tools, AutoTap seems to be the more popular one. What I would do is go to ebay and search on scan tools. There are a few really good ones that sell on there regularly. Just be sure they have GM enhanced parameters.
  1. Tool Definitions
    By Abrasive in forum Off Topic Discussion
    Last Post: 01-31-2012, 04:14 PM
