what is the best rocker bolts you can buy? is it the comp reusables? if so is it a good idea to use threadlocker?
I vote for anyone that is not stripped. I use the comp reusable ones.
Comp Rocker bolts with a DOT of thread locker...thats it
red or blue threadlocker?
the ones that keep the rockers from coming loose are best. if someone could tell you the bolt size/length of the reusable bolts then im sure you can find some grade 8's at the hardware store for about 1/4 the price.
Because they were made to be modified...TTY bolts bend a little after being TQ'ed to a certain spec. Hence why you can only use them once. Cant remember but I actually found the EXACT reusable rocker bolt over at Westlake ACE hardware here in KC...$.68 a pop
it might not be inferior.... but why chance it. 20 bucks is not whole lot to get some rocker bolts
if your gonna buy gm bolts why not just buy them from gm and not pay the mark up prices of zzp or intense...
Grade 8 is a grade 8. I trusted them to hold my seat in my jeep with my 220lb ass bah haing threw a field, I am sure they can hold a rocker down.
