exactly what the title says is it true??? thanks.![]()
help?
Sure will, i had it on there for a long time until recently.
good saved me 25 bucks thanks man ha
do you really notice alot more power with the 3.4? yes i have supporting mods
well...there may be enough travel in the tensioner for the 3.4" pulley however it may not be tight and i'd highly recommend a different belt for a 3.4" pulley to prevent any slippage and for best performance. That's what i did (4060660) that is the size for a serpentine belt.
It's definitely a boost in power that is easily felt. What made me notice it is being able to stomp on it at 35-40 mph and burn rubber with traction control ON (compared to like 15-25 stock). Also being able to chirp second gear is a good sign too. I can't really say much about it, because the day i took delivery of my car it wasn't licensed and i mashed it once, it was stock then. By the end of that night i had put on my 4" FWI, plugs, and TB spacer. And in another week i had the DP on, t-stat, and 3.4 setup. The 3.4 setup, when modded correctly with 0* KR, like my setup, is a night and day comparison to a stock vehicle.
Also , pizzi22 is correct. It will work, but i also made the switch to a tighter belt. If you want to use your stock one and don't want to fork over the cash, buy an oversized tensioner.
You need a tighter belt to make sure it won't slip. I'd also replace the tensioner pulley with a 3.5" pulley too (verses the stock 3.0")...
i dont want to mod any other pulleys except my 3.4 blower pulley what belt do u guys recoomend thanks i get 1 for free from autozone "rewards 20 dollar credit" lol if you have a part number id appreciate it thanks.
Get the Gatorback belt from autozone. 4060660. that is the belt size. it's 66". it's for a 3.4" pulley
thats what i thought pizzi but isnt that the stock belt size now?? thanks man
The 4060660 belt fits a 3.25-3.5 pulley. The stock belt ends in 060667.
ok cool 22 bucks for the gatorback at AZ for the 660 belt thanks alot man![]()
Correction it may end in 663. Anyhow, all the belt sizes are listed on Goodyears website.
No problem 660 is the way to go. I got the same belt with the 3.4 zzp mps also. No slip.
I had slight belt slip with the stock belt on my 3.4. Switched to the 660 and no more slip.
sweeeet ill pick one up this weekend when i do the swap im so excited! lol
