Thread: Vacuum line
Results 1 to 10 of 10
  1. #1 Vacuum line
    SE Level Member drewz313's Avatar
    Morgantown, wv
    I got my used engine installed and running today. There is one vacuum line that I cannot figure out. It is a small line that runs from the passenger side in a harness under the fuse panel in the engine compartment along the firewall right to the brake booster. Not sure where this plugs in at. Any help would be great.
  2. #2 Re: Vacuum line
    Jan 2009
    Grand Rapids, MI
    possiby one of the vac lines of the tree on top of the sc?
    XP~GEN V~SSIC~2.8~HEADERS~P&P HEADS~78mm TB~SLP LOUDMOUTH
    318 whp, pump 92 octane, 18" wheels
    Before Gen V
  3. #3 Re: Vacuum line
    Morgantown, wv
    I looked at that. Its not long enough. Thank you though.
  4. #4 Re: Vacuum line
    GTX Level Member 97gtsc's Avatar
    Jul 2008
    Livonia MI.
    Its for your hvac
  5. #5 Re: Vacuum line
    Morgantown, wv
    Ok so where does that plug into?
  6. #6 Re: Vacuum line
    Jul 2008
    Livonia MI.
    It goes to your heater box and controls
  7. #7 Re: Vacuum line
    GTP Level Member Scimmia's Avatar
    QCA, IA
    It goes to the middle port on the "tree" on top of the blower.
    2001 Buick Regal LS - Almost Stock
  8. #8 Re: Vacuum line
    Morgantown, wv
    Do you have a picture of that ?
  9. #9 Re: Vacuum line
    QCA, IA
    Not off hand, but it's pretty straight forward. There's 3 ports on a black plastic manifold on top of the supercharger. The back one goes to the brake booster, the middle one goes to the HVAC, and the front one goes to the BBV acutator.
  10. #10 Re: Vacuum line
    Morgantown, wv
    Thank you. That one was plugged off on the used engine. I guess that the park avenue didn't use that port.
  1. TB vacuum line thing
    By Skeeve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-24-2009, 06:54 AM
  2. Boost Gauge and vacuum line
    By anicolay in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-22-2009, 12:58 PM
  3. Got pictures for my vacuum line where does it go
    By chrizzle17 in forum General Tech Discussion
    Last Post: 03-09-2009, 02:49 PM
  4. Vacuum line...where does it go
    Last Post: 02-25-2009, 11:15 PM
  5. Vacuum line for Fuel Press Regulator, where does it go?
    By 97grandprix38 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2008, 12:17 AM
