Thread: Coolant pouring out of TB upon throttle!!!
Results 1 to 7 of 7
  1. #1 Coolant pouring out of TB upon throttle!!!
    Ontario
    So Ive replaced my LIM & UIM Gasket Spark Plugs CPS
    1) Car started up fine blew some smoke from existing coolant on the cylinders
    2) Took it for a spin and it overheated, took it home popped the hood and everytime i engage the throttle COOLANT POURS OUT OF THE END OF THE TB!!!!
    any ideas???
  2. #2 Re: Coolant pouring out of TB upon throttle!!!
  3. #3 Re: Coolant pouring out of TB upon throttle!!!
    Wausau, WI
    take your TB off and see where it is leaking...
  4. #4 Re: Coolant pouring out of TB upon throttle!!!
    Ontario
    I did take it off but cant tell where it is coming from...Are there coolant lines that go to the throttle body??? and if my Tb wasnt tight could this be a problem because its a brand new gasket
  5. #5 Re: Coolant pouring out of TB upon throttle!!!
    the coolant flows through the TB on the bottom of it. its to heat it up for cold weather.
  6. #6 Re: Coolant pouring out of TB upon throttle!!!
    Ontario
    lol so if the bottom isnt tightened then it will spit coolant into your tb then???
  7. #7 Re: Coolant pouring out of TB upon throttle!!!
    Feb 2008
    San Diego, CA
    I'm assuming n/a L36?
    Yes, if the TB nuts are not tightened properly, or if they can't be because the retained nuts in the UIM are spun, or the UIM is cracked, warped or broken, or the TB gasket is broken or rolled or not installed right, then coolant will spill out between the UIM and TB.
  1. throttle body
    By blown gt in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-08-2009, 03:13 PM
  2. Throttle Bodies ?
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-02-2009, 11:03 AM
  3. i make wa baypass for the coolant to the throttle body opinions
    By gpracing in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-06-2008, 11:22 PM
