Thread: engine will not idle
Results 1 to 9 of 9
  1. #1 engine will not idle
    CT
    i was driving down the highway at 70 mph and the engine just stopped running. it will turn over fine but it is very diffacult if impossible to keep it running. i no ses warning and it has been checked for codes and there are none.
    there seems to be no vacuum leaks and the wiring is fine.
    i have a 99 gtp with mild modifications.
    any suggestions on what to check next?
    thanks
  2. #2 Re: engine will not idle
    Jul 2008
    sumter,south carolina
    have u checked the schrader valve on the fuel rail to see if its getting fuel?
    02 GTP with mods 05 GP for DD
  3. #3 Re: engine will not idle
    CT
    no i haven't, i had to get the car towed to a garage and they have not done much yet. they have checked for codes and found none. i have headers and a intense air intake system on this car. i believe this valve must be what makes so much noise until the car is warmed up. it sounds
    like the transission is going to fall out.
    if they can not find something on monday i am going to take the car back and do whatever suggestions i get from this post.
    thanks
  4. #4 Re: engine will not idle
    Jul 2008
    if ur talking about the noise that i think u are... thats just ur intake sucking in alot of air... all aftermarket intakes do that on cold starts. also try turning ur key in the on position ( dont crank) listen carefully to see if the fuel pump is purging.
  5. #5 Re: engine will not idle
    Jan 1970
    Maquoketa, Iowa
    Could be a few things... check fuel pump like said above and maybe even the maf if it is running but hard to keep running.
  6. #6 Re: engine will not idle
    CT
    the noise it makes, when cold, is terrible.
    i checked the pump by turning the key to the on position and the pump is purging.
    the garage was waiting on a maf to replace that to see if that was the problem.
    i have never had a car run this bad and not throw any codes.
  7. #7 Re: engine will not idle
    Barksdale AFB, LA
    A simple troubleshooting step to the MAF is to unplug it. If the car starts with it unplugged, the MAF is your problem.
    2009 Subaru Impreza WRX STI
  8. #8 Re: engine will not idle
    Quote Originally Posted by Sabrewings View Post
    Beat me to it.
  9. #9 Re: engine will not idle
    CT
    It was the MAF.
    Thanks for your advice.
  1. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  2. Engine takes too long to idle
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-18-2009, 12:07 AM
  3. Car wont idle help!!!!!!!!
    By GINOSGTP in forum General Tech Discussion
    Last Post: 05-10-2009, 06:30 AM
  4. 1999 SE 3100 Replaced engine, Surging at idle
    By socalchlln in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-09-2009, 10:09 PM
  5. Wased my engine at the car wash 2 weeks ago, still have miss at idle.
    By PCweber in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-07-2009, 05:59 PM
