if you do e85 you will never want to go back
Yeah I know I am not cool enough to make a million threads I plan to run 100% meth with a d05 to start
It ****ing changed it on me I just copied and pasted. I will fix it.
Got one other ? where can I get 100% meth cheap? I know some one asked before, but I did not find the thread after like 5 searches.
Use isopropyl rubbing alcohol.
I can get methanol threw our shop, but I don't know how small of a quantity we can get it in. We used to get 55 gal drums lol.
isopropyl rubbing alcohol is only 70% too. I am looking for 100% or 99.9 is the highest I have herd.
You can buy 91% right on the shelf.
Im interested in meth as well what is the mixture needed per full tank of gas and how often do you have to refill it? thanks have a good one
It only sprays when you are in boost. The kit comes with a progressive controller so you can set it at what boost level you want it to start spraying. The mix is up to you. A lot run 50/50 meth and water. I am going for the octane from meth (116) over the cooling of the water. So I am going to run 100% meth. I will probally experiment with mixes and see what will work the best. I have a 4qt tank that I am going to use to hold the meth.
I will find some somewhere either that or I will go rob the ethanol plant about a mile away from my house. Just have to find the right tank where it is pure alcohol.
Well got the meth kit on today. I am starting with a D03 nozzle with around a 60/40 mix meth water. Went for a test drive and I could feel a difference did not get it dialed in at all. Didn't have to tuner with me. Going to be busy fixing my car and tuning it this week for the club clash on sunday. The part I have to fix is the DP. On the ssauto chrome headers there is a pipe where you can put a cat. I had a band clamp on each side of it. Well it would scrape on the cement going into my garage. I guess I was going a bit to fast in after the test drive and it caught. Pulled the cat back right off the dp. Tommorow I am going to bust out the welder and do it right this time.
