Ok, so I replaced fuel filter, fuel pump, fuel regulator, fuel relays and checked for vaccum leaks and it still does the same thing. Whenever I crank the car it starts up then dies. I try again and give it gas it starts up bogs down, then picks up. Its weird. So im kinda guessing fuel pump resistor now. Does this sound like it might be it? Also where the "f" is it? I popped the hood and took out battery and windshild fluid resevoir and its nowhere along that side.
