Thread: Pulleys = what boost numbers?
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 114
  1. #1 Pulleys = what boost numbers?
    May 2008
    McHenry IL
    I AM UNSURE AND IM SURE ALOT OTHERS GUYS N GALS WHAT ARE THE RELATIONSHIPS FROM BOOST MADE TO THE SIZE OF THE PULLEY? THANKS
  2. #2 Re: Pulleys = what boost numbers?
    Like boost levels compared to pulley size? Because there is no rule of thumb...if your car flows good it makes less boost. Or, could make 15psi on a 3.4" if you don't flow well enough.
    basically...
    3.8" = 5-7psi
    3.5" = 8-9psi
    3.4" = 10-ish psi
    3.2" = 11psi + and so on...for the most part.
  3. #3 Re: Pulleys = what boost numbers?
    Charles City, IA
    ^ thats pretty much it. I see 10.2 right before I shift with my 3.4
    with my 3.5 I saw about 9.4 max.
    SMGPFC Two Nipple General
  4. #4 Re: Pulleys = what boost numbers?
    heh...I saw 15psi with my 3.2"...and it didn't knock at all...and that setup ran like a raped ape. I loved it.
  5. #5 Re: Pulleys = what boost numbers?
    Charles City, IA
    Think what your new set up will be .......
  6. #6 Re: Pulleys = what boost numbers?
    Jan 2009
    Michigan
    i see about 10.5 with a 3.3. fs intercooler, plog, stock rear mani, 3" dp....
    doesnt flow the best lol
  7. #7 Re: Pulleys = what boost numbers?
    Joliet, IL
    i see 12 on my 3.4 with headers
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  8. #8 Re: Pulleys = what boost numbers?
    Quote Originally Posted by BoostJunki3 View Post
    Then it isn't flowing good enough.
    I saw 11 with a 3.25" with headers.
  9. #9 Re: Pulleys = what boost numbers?
    there is no set amount. it depends on how well your motor flows.
    /thread
  10. #10 Re: Pulleys = what boost numbers?
    SE Level Member Zach3800's Avatar
    Waterloo IL
    i only see 9.8 psi on a 3.4 with a huge cam and high compression
    All you need to know is High compression big a$$ Cam plus blower
  11. #11 Re: Pulleys = what boost numbers?
    Donating Users blowfishRus6's Avatar
    g.a.
    weather effects it also does it not??
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  12. #12 Re: Pulleys = what boost numbers?
    Charles City, IA
    yup cold air is denser and then you make more boost.
  13. #13 Re: Pulleys = what boost numbers?
    Wausau, WI
    Quote Originally Posted by Zach3800 View Post
    And I saw a max of 9.0 with my stock 3.8 setup....obviously it is all about flow....headers, porting, exhaust mods, etc.
  14. #14 Re: Pulleys = what boost numbers?
    Waterloo IL
    flow has everything to do with boost levels so does weather
  15. #15 Re: Pulleys = what boost numbers?
    Wichita
    I agree! on a3.4 pulley im seeing 7psi with my port headers & catless exhaust.
  16. #16 Re: Pulleys = what boost numbers?
    Joliet, IL
    im seeing 12 because im boost stacking i believe tho because i get a constant 9-10 then right before the shift it shoots to 12 real quick...
    00 Silvermist GTP
  17. #17 Re: Pulleys = what boost numbers?
    How are you stacking with headers?
    You need a ported blower...and a better tune prolly...
  18. #18 Re: Pulleys = what boost numbers?
    g.a.
    in the video he posted, it dident jump up till right at redline. maybe the supercharger just turning harder, idk
    its slow.
  19. #19 Re: Pulleys = what boost numbers?
    Jan 1970
    Maquoketa, Iowa
    Its a roots blower, It's pushed air. Your not going to have the same psi from car to car, pulley to pulley.
  20. #20 Re: Pulleys = what boost numbers?
    SE Level Member Xhondaguy's Avatar
    May 2008
    chicagoland
    i hit 10 with a stock pulley and minor mods
  1. Ok here is my dyno. Why aren't these the numbers I should be getting?
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 10:14 AM
  2. Here are Tag Numbers.....
    By Roger B in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-24-2009, 02:43 PM
  3. Part numbers
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:50 PM
  4. Numbers
    By 04 GTP COMP G in forum Off Topic Discussion
    Last Post: 07-10-2008, 02:59 PM
  5. XP cam boost and vac numbers
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2008, 10:54 PM
