Thread: Pulleys = what boost numbers?
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 21 to 40 of 114
  1. #21 Re: Pulleys = what boost numbers?
    in a house
    Quote Originally Posted by Xhondaguy View Post
    i hit 10 with a stock pulley and minor mods
    That's horrible! I hope you're not proud of that.
  2. #22 Re: Pulleys = what boost numbers?
    Jesus H Christ.
    Fail.
  3. #23 Re: Pulleys = what boost numbers?
    SE Level Member Xhondaguy's Avatar
    May 2008
    chicagoland
    Its fantastic
  4. #24 Re: Pulleys = what boost numbers?
    Banned - Busted For Scamming
    Feb 2009
    Just went back to the 3.4. I had 5 psi on the stock 3.8. With the 3.4 i have 7psi at WOT. I have ported blower, lim, tb, 1.9 rockers, headers, full exhaust.
  5. #25 Re: Pulleys = what boost numbers?
    even on my setup with all that i was getting around 9 psi max. why is yours so low?
  6. #26 Re: Pulleys = what boost numbers?
    Excessively ported blower?
  7. #27 Re: Pulleys = what boost numbers?
    Feb 2009
    I dont know, its not excessively ported its the same i do for all my other customers. Before the ported blower i had the 3.4 on there, 10 psi of boost max. When i ported the blower, went to the stock 3.8 pulley and observed 5 psi. This weekend i installed the 1.9 modified rockers and it had slightly more pull but not that noticeable. Yesterday i put on the 3.4 again and even though it only has 7 psi versus the 10 before, it has way more power like i can light the tires up from a 20mph roll. This is keeping in mind that i dont have a tuned pcm either so i know there is more to be had.
    Btw, the rotor coating is good in tact also.
  8. #28 Re: Pulleys = what boost numbers?
    Donating Users blowfishRus6's Avatar
    g.a.
    at the top of second at 6k i saw 8psi. top of first it was 7.
    back on the stock tune shifting at 5500rpm i see about 6 at the top of first.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  9. #29 Re: Pulleys = what boost numbers?
    Wausau, WI
    the consensus is...........there is no consensus...all different
  10. #30 Re: Pulleys = what boost numbers?
    Jan 2009
    Michigan
    Quote Originally Posted by Liquifire View Post
    haha x2.
  11. #31 Re: Pulleys = what boost numbers?
    SE Level Member SilverGT's Avatar
    Feb 2009
    Saskatchewan Canada
    wondering if I could drop to a 3.4 with my FWI, tuned pcm, downpipe, wideband and aerforce. Right now I see no KR and good WOT afr.
  12. #32 Re: Pulleys = what boost numbers?
    i would say so if youre not knocking at all now. that wideband helps you out tuning A LOT.
  13. #33 Re: Pulleys = what boost numbers?
    Feb 2009
    Saskatchewan Canada
    I was really suprised seeing no KR through a couple WOT pulls.
  14. #34 Re: Pulleys = what boost numbers?
    Jan 2009
    Michigan
    Quote Originally Posted by SilverGT View Post
    tuned pcm
    whats this mean? custom tune? canned?
  15. #35 Re: Pulleys = what boost numbers?
    Quote Originally Posted by 00gpgtp View Post
    what do you mean what do you mean...a tune is a tune...a canned tune is a vendor bought pre-tuned PCM, a custom tune is a tune specifically made for your mods...did you really just ask that question?
  16. #36 Re: Pulleys = what boost numbers?
    Charles City, IA
    A tune is done by adjusting the valves in the muffler to change the exhaust note.
    SMGPFC Two Nipple General
  17. #37 Re: Pulleys = what boost numbers?
    No no no...that's the nitrous.
  18. #38 Re: Pulleys = what boost numbers?
    Wausau, WI
    or a flute..........damn kids......
  19. #39 Re: Pulleys = what boost numbers?
    Jan 2009
    Michigan
    are you kidding me? i know what a damn tune is. i was asking what kind of tune. no, a tune is not a tune. does he have someone doing his tune, meaning is it easily accessible for him to change something if he needs to. did he buy a zzp 1.0, is it dhp 1.0/5. wtf, come on people.
  20. #40 Re: Pulleys = what boost numbers?
    Dude...you said it...you asked the question we replied...now see if you would have taken the time to be that specific earlier you wouldn't have had the smartass comments you got.
    It was probably a mail order tune...and if you read in his kill stories thread about him running at the track with a bone stock PCM. His old one was a DHP but toasted his motor because he had a high compression setup. And yes...a tune is a tune...no matter how you slice it...just one being better than the other or from a different "tuner" of sorts. If you want to argue about it more feel free to send me a PM.
  1. Ok here is my dyno. Why aren't these the numbers I should be getting?
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2009, 10:14 AM
  2. Here are Tag Numbers.....
    By Roger B in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 03-24-2009, 02:43 PM
  3. Part numbers
    By 99prixgt in forum Brakes/Suspension/Chassis
    Last Post: 10-27-2008, 01:50 PM
  4. Numbers
    By 04 GTP COMP G in forum Off Topic Discussion
    Last Post: 07-10-2008, 02:59 PM
  5. XP cam boost and vac numbers
    By 1998gpgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-27-2008, 10:54 PM
