Thread: Drilling a Tstat????
Results 1 to 8 of 8
  1. #1 Drilling a Tstat????
    GT Level Member WHT98GTP's Avatar
    Monroeville
    Hey guys, I got a replacement 160* tstat for my car and someone mentioned to me that i should drill two small holes in it so I can bypass some of the coolant. Ideas???
    *2002 Buick LeSabre Custom* Bronzemist Metallic * SS Headers *4" FWI*
  2. #2 Re: Drilling a Tstat????
    If your mod list is up to date in your sig, there's no mods I see there that would keep you from running an undrilled 180F. A 160F would be serious overkill and a drilled 160F may not allow you to have heat in the winter. (If you are in a northern climate)
    I'd think you need to upgrade the radiator if you are having cooling issues.
  3. #3 Re: Drilling a Tstat????
    Banned
    Wichita Falls, Texas
    A 160 for you is indeed overkill, however even if you install a 180 you do need to drill it. No if and or buts.
    Being drilled allows a constant flow of (some) coolant therefor preventing, or at least helping to prevent the hairline cracks your heads from forming. Which these engines are surprisingly bad about.
    I makes sense, because to put it very simply. Your not just dumping 'cold' coolant onto a hot motor all at once like you are without it being drilled.
  4. #4 Re: Drilling a Tstat????
    what the hell do you need a 160* thermostat for? even the most highly modded guys dont even need to run that cold.
  5. #5 Re: Drilling a Tstat????
    GTX Level Member Jakegday's Avatar
    Nov 2008
    Fremont Nebraska
    wont a 160 degree thermostat cause the SES light to come on? something about it taking the engine too long to warm up?
    2001 GT: cat/ubend/resonator delete, zzp PLOG, custom intake, DHP pcm
  6. #6 Re: Drilling a Tstat????
    the engine will still take the same amount of time to warm up to that 160*, but it will run cold, MPG will suffer, and you might throw an SES. a cold engine is always the fastest engine, but 160* is pushing that limit. thats besides the fact that your radiator fans will probably never turn off.
  7. #7 Re: Drilling a Tstat????
    Drilled T-Stats = fail
    Especially in a colder climate...just put a non-drilled 180* in your car...it'll run great.
  8. #8 Re: Drilling a Tstat????
    drilled stat is a waste...just put a 180 in...
  1. 180 tstat
    By bballa0740 in forum General Tech Discussion
    Last Post: 10-03-2009, 08:31 AM
  2. 180 tstat question
    By superv6 in forum General Tech Discussion
    Last Post: 04-17-2009, 12:25 PM
  3. Drilling holes in the trunk???
    By MysticStyl3z in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2008, 10:58 AM
  4. drilling/tapping blower case?
    By Bio248 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2008, 07:41 AM
  5. 180 degree Tstat
    By bula81069 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-13-2008, 02:05 PM
