Thread: What bolts are torque to yeild
Results 1 to 8 of 8
  1. #1 What bolts are torque to yeild
    SE Level Member slednut's Avatar
    Feb 2009
    Canada
    Completly dissasembling my enigne and was wonder what bolts are torque to yeild. I know that head bolts are, what about rocker, main, and rods. Or any other. Any i should replace anyways. Thanks
  2. #2 Re: What bolts are torque to yeild
    Any bolt that has a torque value of X + degrees is a stretching TTY.
  3. #3 Re: What bolts are torque to yeild
    GT Level Member tylerbinski's Avatar
    Canada
    Rocker bolts
    Flex plate bolts (flex plate to crank)
    Torque converter to flex plate bolts
    connecting rod bolts
    Main bolts ?? - i think.. might be wrong here
    Cam bolt
    crank bolt
    Head bolts
    Buy ARP head studs, main studs, connecting rod bolts and reusable rocker bolts..
    GoodLuck!
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  4. #4 Re: What bolts are torque to yeild
    Canada
    Great answer... Not sure I caught onto that
  5. #5 Re: What bolts are torque to yeild
    get main studs, head studs, and reusable rocker bolts. no more TTY for the parts that matter.
    and for the record, i have reused TTY bolts in a few places (rockers and crank bolt).
  6. #6 Re: What bolts are torque to yeild
    Yeah we even reused TTY head bolts in my buddy's Five Oh...but then again...it was a Mustang...I looked like this: O_o When he was putting them BACK IN.
    I wish I would have bought Head/Main studs if I would have known I'd be going through this many motors LOL
  7. #7 Re: What bolts are torque to yeild
    Feb 2009
    Canada
    So i was looking at main studs and it said as a note that you should have the mains line bored with them in. Is that necessary. And with the rod bolts it said that machine shop work is needed. Can some one explain why to me cause i don't get it.
  8. #8 Re: What bolts are torque to yeild
    If you are getting ARP Main studs then yes...you need the block line bored...I am in the process of having mine done.
  1. 6 Bolts or 5?
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2009, 03:09 PM
  2. Replies: 12
    Last Post: 02-08-2009, 01:06 AM
  3. S/C Bolts ?
    By Meemperor in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-12-2008, 03:18 PM
