Thread: just bought a 1998gtp need some advice
Results 1 to 7 of 7
  1. #1 just bought a 1998gtp need some advice
    canada
    Shimmy is doing all my maintence work, work befor i start mods.
    plugs, wires, lower intake manifold gaskets, coolent fiush, rocker cover gaskets,3 new pullies,
    esh oil, filter fuel filter. check 02 sensers.
    new super charger belts, super charger fluid, flip motor mounts.
    mod plans...
    Ported Gen 3 and LIM (Painted black) - $200 PRICE DROP - $180 Pending
    TOG's With catless DP and brand new prebent dipstick - $400 Pending
    tstat
    i am getting this pakage for 550.00 ^^^^^^^^^^^ from matt(meemperor)
    and adding a pullie 3.4 or lower if possible and safe, the lowest pullie i want to run is 3.25.
    tune from will
    fenderwell intake
    N* throttle body.
    1.8 or 1.9 roller rockers
    mabey a intercooler if i can find a use one
    i don't want to do a engine or tranny rebuild i think i will be happy with a 3.25 pullie
    1998 gtp 184000km
    i dont want to go to extreme because its my daily driver.
    is this a good setup?
    will it be alot more fun to drive then stock?
    thanks
  2. #2 Re: just bought a 1998gtp need some advice
    Charles City, IA
    No way you will run that small of a pulley with those mods. Read the safely modding your 3800 thread.
    SMGPFC Two Nipple General
  3. #3 Re: just bought a 1998gtp need some advice
    canada
    i did read it, very good write up.
    only way i am dropping lower the a 3.4 is if and when i get a intercooler.
    i am not sure how much gain a 3.25 pullie is but 500.00 for a use intercooler so u can run it safely isn't that much.
  4. #4 Re: just bought a 1998gtp need some advice
    canada
    tstat
    and adding a pullie 3.4 tune from will
    fenderwell intake
    can i install 3.29 gears with out rebuilding and strengthening the whole tranny??? aprox cost for gear and install??? please.
    or what should i do instead without getting to extreme, would a intercooler and 3.25 pullie drop be best
  5. #5 Re: just bought a 1998gtp need some advice
    with headers and rockers you can easily run a 3.4, maybe even a 3.2 with the right tune (conservative enough).
    with an intercooler i would go straight to a 3.2, maybe a 3.0.
  6. #6 Re: just bought a 1998gtp need some advice
    im IC and have pogs and run a 3.1 just fine...
  7. #7 Re: just bought a 1998gtp need some advice
    So...all those PM's were pointless...
    awesome.
  1. just bought car need advice
    By olds95supreme in forum Visual/Body Modifications
    Last Post: 07-13-2009, 12:28 PM
  2. Jus bought a GTP
    By flash527 in forum Introductions/Noob Questions
    Last Post: 06-21-2009, 10:55 PM
  3. Tune Up Advice, Just bought High Mileage Grand Prix GT
    By anicolay in forum General Tech Discussion
    Last Post: 04-29-2009, 02:57 PM
  4. So I Bought Some =]
    Last Post: 01-26-2009, 11:13 PM
