Im gonna be doing an install before i head to ZZP so i dont have to pay an outrageous 1000 dollars for labor install. I have an XP cam, ZZP CNC Ported Heads with 105 springs, ZZP 7.05 pushrods, OE-R 875 lifters, Pacesetters, 42.5 injectors, 3.0 S/C pulley, 85mm MAF, fuel pump re-wire and Rollmaster Double Roller Timing Chain all on its way and am just wondering some things before i tear into it.
Should i get rockers?
What kind of rockers should i get?
Do i need to put new cam bearings in?
What problems will i run into?
All help would be greatly appreciated. Thanks.
******Updated******
Decided to scrap the whole deal with ZZP and went with the INTENSE. I am now doing the Intense Stage 4 Heads and Cam pckage. Cometic .52/ 3.84" bore Head Gaskets, INTENSE 7.05" Oil Restricted Pushrods, JP Double Roller, 42.5 lb. Injectors Meziere Electric Water Pump, 3.0 pulley, OE-R 875, Pacesetters.
