Thread: ZZP XPZ Build
Page 4 of 13 FirstFirst ... 23456 ... LastLast
Results 61 to 80 of 255
  1. #61 Re: Cam, Heads, Etc. Install *Updated with Pics*
    Donating Users bbptech's Avatar
    Box Elder, South Dakota
    Where can i pick up some LS7 lifters?
    ZZP 10.4mm's, ZZP S2 IC, 3.4, 3.0, Ported Gen V, ZZP Headers, ZZP CNC Heads, ZZP 78mm TB, ZZP Aluminum Valve Covers, Meziere Electric WP, ZZP Fuel Pump, ZZP Fuel Logs, 65 Mototrons, 3.29's, 2500 Stall. Tuned by GLANZERGTX and Kyle. E85 Converted, 21* Timing
  2. #62 Re: Cam, Heads, Etc. Install *Updated with Pics*
    id seriously try ls1tech.com or other lsx forums, seems like most forums have hella good deals and i wouldnt think they'd be hard to find. Def stay out of the stealerships like the others said.
  3. #63 Re: Cam, Heads, Etc. Install *Updated with Pics*
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by bbptech View Post
    A set is pretty cheap from gmpartsdirect. Ordering a set of lifters for the 3800 *should* get you the LS7 lifters, assuming they don't have any old stock lying around. Most people buy the set of 16 for the LSx because they specifically say they're the updated design from the LS7.
    The part numbers have been posted on here, I'm sure a search would turn them up.
    2001 Buick Regal LS - Almost Stock
  4. #64 Re: Cam, Heads, Etc. Install *Updated with Pics*
    Charles City, IA
    Only use Red for Exhaust IMO.
    Why not use the RTV that is designed for exhaust? Ultra copper. Red is not sensor safe and could kill your 02 sensor.
    SMGPFC Two Nipple General
  5. #65 Re: Cam, Heads, Etc. Install *Updated with Pics*
    I don't use it on the o2 sensor. Plus...when it burns off it is after the o2 sensor anyways so it doesn't matter.
    Quote Originally Posted by Scimmia View Post
    Yezzir...just go google LS7 lifters...buy them as a set from a Corvette sire or something...I got mine for around 100 shipped IIRC.
  6. #66 Re: Cam, Heads, Etc. Install *Updated with Pics*
    Alright ima do that. But what about the whole MLS head gaskets bio was talking about? Why cant i use the copper spray for sealing when thats what its used for? Ima put my lifters up for sale in the for sale section.
  7. #67 Re: Cam, Heads, Etc. Install *Updated with Pics*
    QCA, IA
    A lot of people run the MLS gaskets. I've heard that the best procedure is to drill out the rivets, clean and spray each layer. People have said they've found dirt between the layers stock. Whether it's worth it is up to you.
  8. #68 Re: Cam, Heads, Etc. Install *Updated with Pics*
    is this the part number to the LS7 lifters, 20-12499225?
  9. #69 Re: Cam, Heads, Etc. Install *Updated with Pics*
    SE Level Member bigdawg15005's Avatar
    pittsburgh,pa
    gm part # 12499225 www.gmpartshouse.com 120.00 new. unless anyone else has a cheaper place they can get them from let me know also. hope this helps you out.
  10. #70 Re: Cam, Heads, Etc. Install *Updated with Pics*
    pittsburgh,pa
    ha well they were 120.00 just checked again and they are now 132.00 ..sorry havent checked on them in a lil while.
  11. #71 Re: Cam, Heads, Etc. Install *Updated with Pics*
    haha 132.00 is better than 149.99 where i see them.
  12. #72 Re: Cam, Heads, Etc. Install *Updated with Pics*
    just use stock head gaskets, seriously. i wouldnt even risk the MLS for fear of having to take the motor apart again. i didnt see it, but did you get head studs? now is a FANTASTIC time to buy them.
  13. #73 Re: Cam, Heads, Etc. Install *Updated with Pics*
    X2 on he studs...I wish I would have bought them back in the day...would have saved me a BUNCH of money on the multiple TTY head bolt sets I bought. Get them from ARP. IIRC mine were about $116 shipped from Texas Speed...yes the comany that was ruining LSx motors from their bad heads/cams LOL
  14. #74 Re: Cam, Heads, Etc. Install *Updated with Pics*
    Yup bio i already got ARP Head Studs. U gotta answer my question first before i decide to run stock head gaskets. Am i going to be able to run stockers with the IS4 Heads?
  15. #75 Re: Cam, Heads, Etc. Install *Updated with Pics*
    Here some new pics.
  16. #76 Re: Cam, Heads, Etc. Install *Updated with Pics*
    Banned - Busted For Scamming
    Feb 2009
    Omg who ported that badass blower for you?
  17. #77 Re: Cam, Heads, Etc. Install *Updated with Pics*
    Omg u did! haha.
  18. #78 Re: Cam, Heads, Etc. Install *Updated with Pics*
    Feb 2009
    Yea, i know.
    I still say you should put the snail on and be done with it.
  19. #79 Re: Cam, Heads, Etc. Install *Updated with Pics*
    Lol what do u mean Logan?
  20. #80 Re: Cam, Heads, Etc. Install *Updated with Pics*
    actually everything looks great and i admire you for going this far with it. that is a BIG setup to undertake as quickly as you did. good work.
    as far as the gaskets go, theyll work. the heads are still the same size and shape, so why wouldnt the regular ones work? they are way easier to get to seal in my opinion. if you feel like taking the time (and possibly redoing later) with the MLS then go for it.
  1. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
  2. Any other Ska heads out there?
    By Thunderturd in forum Off Topic Discussion
    Last Post: 08-20-2009, 03:18 PM
  3. L67 heads
    By DLAVENGER in forum General Tech Discussion
    Last Post: 06-24-2009, 07:03 AM
  4. L36 Heads
    By Abrasive in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-13-2008, 09:02 AM
